[mpich-discuss] Problems install MPICH2 on Solaris 10 i386_64
Timothy LeBlanc timothy.leblanc at gmail.com
Thu Jun 3 13:29:31 CDT 2010
Hi Rajeev
Thanks for looking into this for me.
--divide does not seem to be an acceptable parameter . When I type in
configure --help it is not listed and it fails when I try using it.
I tried:
./configure CFLAGS=-Wa,--divide --prefix=/usr/local/bin/mpich2-install 2>&1
| tee c.txt
./configure --divide
So I followed up with running:
./configure CFLAGS=-Wa, --prefix=/usr/local/bin/mpich2-install 2>&1 | tee
c.txt
And this fails in the same way as I explained. Seems to configure ok but
then the make fails.
FYI I have been using make clean and deleting the install directory after
each attempt.
Thanks
Tim
On Thu, Jun 3, 2010 at 1:57 PM, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
> Try configuring with CFLAGS=-Wa,--divide . See also this ticket:
> http://trac.mcs.anl.gov/projects/mpich2/ticket/548
> Rajeev
> ________________________________
>        From: mpich-discuss-bounces at mcs.anl.gov [mailto:
> mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Timothy LeBlanc
>        Sent: Wednesday, June 02, 2010 5:25 PM
>        To: mpich-discuss at mcs.anl.gov
>        Subject: [mpich-discuss] Problems install MPICH2 on Solaris 10
> i386_64
>        Hello
>        I'm new to Solaris and I have been trying to install MPICH2 on
> Solaris 10 I have set up a VMimage and installed Solaris 10
> and also all the packages on the companion cd.
>        To install mpich2 I ran
>        ./configure --prefix=/usr/local/bin/mpich2-install 2>&1 | tee c.txt
>         output:
>            config.status: creating include/mpitestconf.h
>            config.status: executing default-1 commands
>            config.status: executing default-2 commands
>            config.status: executing default-3 commands
>            Configuration completed.
>        I then tried to build MPICH2 with:
>        make 2>&1 | tee m.txt
>        and got the following errors:
>          CC              dataloop.c
>        /var/tmp//ccHcN5Kf.s: Assembler messages:
>        /var/tmp//ccHcN5Kf.s:395: Error: suffix or operands invalid for
> `mov'
>        /var/tmp//ccHcN5Kf.s:403: Error: suffix or operands invalid for
> `mov'
>        *** Error code 1
>        The following command caused the error:
>        gcc -DHAVE_CONFIG_H -I. -I. -I./..
> -I/work/mpich2/mpich2-1.2.1p1/src/include
> -I/work/mpich2/mpich2-1.2.1p1/src/include -O2
> -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src
> -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS
> -I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/include
> -I/work/mpich2/mpich2-1.2.1p1/src/mpid/common/datatype
> -I/work/mpich2/mpich2-1.2.1p1/src/mpid/common/locks
> -I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/include
> -I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/include
> -I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor
> -I/work/mpich2/mpich2-1.2.1p1/src/util/wrappers
> -I/work/mpich2/mpich2-1.2.1p1/src/util/wrappers -c dataloop.c
>        make: Fatal error: Command failed for target `dataloop.o'
>        Current working directory
> /work/mpich2/mpich2-1.2.1p1/src/mpid/common/datatype/dataloop
>        *** Error code 1
>        (cd dataloop && make all )
>        make: Fatal error: Command failed for target `all-redirect'
>        *** Error code 1
>        I have read through many of your post and could not find anything to
> relate to my issue.
>        Any help would be greatly appreciated. I'm including my c.txt file
> m.txt file and my config file to help
>        Thanks
>        Tim
>        The information contained in this E-mail message is privileged,
> confidential, and may be protected from disclosure; please
> be aware that any other use, printing, copying, disclosure or dissemination
>        of this communication may be subject to legal restriction or
> sanction. If you think that you have received this E-mail
> message in error, please reply to the sender and delete it from your
> computer. Thank you.
> mpich-discuss mailing list
confidential, and may be protected from disclosure; please be aware that any
of this communication may be subject to legal restriction or sanction. If
you think that you have received this E-mail message in error, please reply
to the sender and delete it from your computer. Thank you.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100603/6a5bf3e8/attachment.htm>
