[mpich-discuss] Problems install MPICH2 on Solaris 10 i386_64
    Rajeev Thakur
    thakur at mcs.anl.gov
    Thu Jun  3 12:57:12 CDT 2010
Try configuring with CFLAGS=-Wa,--divide . See also this ticket: http://trac.mcs.anl.gov/projects/mpich2/ticket/548
Rajeev
	From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Timothy LeBlanc
	Sent: Wednesday, June 02, 2010 5:25 PM
	Subject: [mpich-discuss] Problems install MPICH2 on Solaris 10 i386_64
	Hello
	I'm new to Solaris and I have been trying to install MPICH2 on Solaris 10 I have set up a VMimage and installed Solaris 10
and also all the packages on the companion cd.
	To install mpich2 I ran
	./configure --prefix=/usr/local/bin/mpich2-install 2>&1 | tee c.txt
	 output:
	    config.status: creating include/mpitestconf.h
	    config.status: executing default-1 commands
	    config.status: executing default-2 commands
	    config.status: executing default-3 commands
	    Configuration completed.
	I then tried to build MPICH2 with:
	make 2>&1 | tee m.txt
	and got the following errors:
	  CC              dataloop.c
	/var/tmp//ccHcN5Kf.s: Assembler messages:
	/var/tmp//ccHcN5Kf.s:395: Error: suffix or operands invalid for `mov'
	/var/tmp//ccHcN5Kf.s:403: Error: suffix or operands invalid for `mov'
	*** Error code 1
	The following command caused the error:
	gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/work/mpich2/mpich2-1.2.1p1/src/include -I/work/mpich2/mpich2-1.2.1p1/src/include -O2
-I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS
-I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/include -I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/include
-I/work/mpich2/mpich2-1.2.1p1/src/mpid/common/datatype -I/work/mpich2/mpich2-1.2.1p1/src/mpid/common/datatype
-I/work/mpich2/mpich2-1.2.1p1/src/mpid/common/locks -I/work/mpich2/mpich2-1.2.1p1/src/mpid/common/locks
-I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/include
-I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/include
-I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor
-I/work/mpich2/mpich2-1.2.1p1/src/util/wrappers -I/work/mpich2/mpich2-1.2.1p1/src/util/wrappers -c dataloop.c
	make: Fatal error: Command failed for target `dataloop.o'
	Current working directory /work/mpich2/mpich2-1.2.1p1/src/mpid/common/datatype/dataloop
	*** Error code 1
	(cd dataloop && make all )
	make: Fatal error: Command failed for target `all-redirect'
	*** Error code 1
	I have read through many of your post and could not find anything to relate to my issue.
	Any help would be greatly appreciated. I'm including my c.txt file m.txt file and my config file to help
	Thanks
	Tim
	The information contained in this E-mail message is privileged, confidential, and may be protected from disclosure; please
be aware that any other use, printing, copying, disclosure or dissemination
	of this communication may be subject to legal restriction or sanction. If you think that you have received this E-mail
message in error, please reply to the sender and delete it from your computer. Thank you.
