[mpich-discuss] Problems install MPICH2 on Solaris 10 i386_64
    Timothy LeBlanc
    timothy.leblanc at gmail.com
    Wed Jun  2 17:24:51 CDT 2010
Hello
I'm new to Solaris and I have been trying to install MPICH2 on Solaris 10 I
have set up a VMimage and installed Solaris 10 and also all the packages on
the companion cd.
To install mpich2 I ran
./configure --prefix=/usr/local/bin/mpich2-install 2>&1 | tee c.txt
 output:
    config.status: creating include/mpitestconf.h
    config.status: executing default-1 commands
    config.status: executing default-2 commands
    config.status: executing default-3 commands
    Configuration completed.
I then tried to build MPICH2 with:
make 2>&1 | tee m.txt
and got the following errors:
  CC              dataloop.c
/var/tmp//ccHcN5Kf.s: Assembler messages:
/var/tmp//ccHcN5Kf.s:395: Error: suffix or operands invalid for `mov'
/var/tmp//ccHcN5Kf.s:403: Error: suffix or operands invalid for `mov'
*** Error code 1
The following command caused the error:
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/work/mpich2/mpich2-1.2.1p1/src/include
-I/work/mpich2/mpich2-1.2.1p1/src/include -O2
-I/work/mpich2/mpich2-1.2.1p1/src/openpa/src
-I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS
-I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/include
-I/work/mpich2/mpich2-1.2.1p1/src/mpid/common/datatype
-I/work/mpich2/mpich2-1.2.1p1/src/mpid/common/locks
-I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/include
-I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/include
-I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor
-I/work/mpich2/mpich2-1.2.1p1/src/util/wrappers
-I/work/mpich2/mpich2-1.2.1p1/src/util/wrappers -c dataloop.c
make: Fatal error: Command failed for target `dataloop.o'
Current working directory
/work/mpich2/mpich2-1.2.1p1/src/mpid/common/datatype/dataloop
*** Error code 1
(cd dataloop && make all )
make: Fatal error: Command failed for target `all-redirect'
*** Error code 1
I have read through many of your post and could not find anything to relate
to my issue.
Any help would be greatly appreciated. I'm including my c.txt file m.txt
file and my config file to help
Thanks
Tim
The information contained in this E-mail message is privileged,
confidential, and may be protected from disclosure; please be aware that any
other use, printing, copying, disclosure or dissemination
of this communication may be subject to legal restriction or sanction. If
you think that you have received this E-mail message in error, please reply
to the sender and delete it from your computer. Thank you.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100602/8b0546d9/attachment-0001.htm>
Configuring MPICH2 version 1.2.1p1 with  '--prefix=/usr/local/bin/mpich2-install'
Running on system: SunOS mars 5.10 Generic_141445-09 i86pc i386 i86pc
Executing mpich2prereq in /work/mpich2/mpich2-1.2.1p1/src/mpid/ch3 with
Executing mpich2prereq in /work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis
sourcing /work/mpich2/mpich2-1.2.1p1/src/pm/mpd/mpich2prereq
sourcing /work/mpich2/mpich2-1.2.1p1/src/pm/hydra/mpich2prereq
sourcing /work/mpich2/mpich2-1.2.1p1/src/pm/gforker/mpich2prereq
sourcing /work/mpich2/mpich2-1.2.1p1/src/pm/mpd/setup_pm
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking whether the compiler defines __func__... yes
checking whether the compiler defines __FUNC__... no
checking whether the compiler sets __FUNCTION__... yes
checking whether C compiler accepts option -O2... yes
checking whether routines compiled with -O2 can be linked with ones compiled without -O2... yes
checking for type of weak symbol alias support... pragma weak
checking whether __attribute__ ((weak)) allowed... yes
checking whether __attribute ((weak_import)) allowed... yes
checking for multiple weak symbol support... yes
checking for g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... no
checking for g95... no
checking for xlf95... no
checking for f95... no
checking for fort... no
checking for ifort... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for ftn... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether  accepts -g... no
checking for c++... c++
checking whether we are using the GNU C++ compiler... yes
checking whether c++ accepts -g... yes
checking whether the C++ compiler c++ can build an executable... yes
checking whether C++ compiler works with string... yes
checking whether the compiler supports exceptions... yes
checking whether the compiler recognizes bool as a built-in type... yes
checking whether the compiler implements namespaces... yes
checking whether <iostream> available... yes
checking whether the compiler implements the namespace std... yes
checking whether <math> available... no
checking for GNU g++ version... 3 . 4
checking whether C++ compiler accepts option -O2... yes
checking for perl... /usr/bin/perl
checking for ar... ar
checking for ranlib... ranlib
checking for killall... killall
checking for a BSD-compatible install... confdb/install-sh -c
checking whether install works... yes
checking whether install breaks libraries... no
checking whether mkdir -p works... yes
checking for make... make
checking whether clock skew breaks make... no
checking whether make supports include... yes
checking whether make allows comments in actions... yes
checking for virtual path format... VPATH
checking whether make sets CFLAGS... no
checking for bash... /usr/bin/bash
checking whether /usr/bin/bash supports arrays... yes
checking for doctext... false
checking for location of doctext style files... unavailable
checking for an ANSI C-conforming const... yes
checking for working volatile... yes
checking for C/C++ restrict keyword... __restrict
checking for inline... inline
checking whether __attribute__ allowed... yes
checking whether __attribute__((format)) allowed... yes
checking whether byte ordering is bigendian... no
checking whether C compiler allows unaligned doubles... yes
checking whether gcc supports __func__... yes
Using gcc to determine dependencies
checking whether long double is supported... yes
checking whether long long is supported... yes
checking for max C struct integer alignment... four
checking for max C struct floating point alignment... four
checking for max C struct alignment of structs with doubles... four
checking for max C struct floating point alignment with long doubles... four
checking if alignment of structs with doubles is based on position... no
checking if alignment of structs with long long ints is based on position... no
checking if double alignment breaks rules, find actual alignment... no
checking for alignment restrictions on pointers... int or better
checking size of char... 1
checking size of unsigned char... 1
checking size of short... 2
checking size of unsigned short... 2
checking size of int... 4
checking size of unsigned int... 4
checking size of long... 4
checking size of unsigned long... 4
checking size of long long... 8
checking size of unsigned long long... 8
checking size of float... 4
checking size of double... 8
checking size of long double... 12
checking size of void *... 4
checking for ANSI C header files... no
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking size of wchar_t... 4
checking size of float_int... 8
checking size of double_int... 12
checking size of long_int... 8
checking size of short_int... 8
checking size of two_int... 8
checking size of long_double_int... 16
checking sys/bitypes.h usability... no
checking sys/bitypes.h presence... no
checking for sys/bitypes.h... no
checking inttypes.h usability... yes
checking inttypes.h presence... yes
checking for inttypes.h... yes
checking stdint.h usability... yes
checking stdint.h presence... yes
checking for stdint.h... yes
checking for int8_t... yes
checking for int16_t... yes
checking for int32_t... yes
checking for int64_t... yes
checking for uint8_t... yes
checking for uint16_t... yes
checking for uint32_t... yes
checking for uint64_t... yes
checking size of _Bool... 1
checking size of float _Complex... 8
checking size of double _Complex... 16
checking size of long double _Complex... 24
checking for _Bool... yes
checking for float _Complex... yes
checking for double _Complex... yes
checking for long double _Complex... yes
checking size of bool... 1
checking how to run the C++ preprocessor... c++ -E
checking complex usability... yes
checking complex presence... yes
checking for complex... yes
checking size of Complex... 8
checking size of DoubleComplex... 16
checking size of LongDoubleComplex... 24
checking if char * pointers use byte addresses... yes
checking for alignment restrictions on ... no
checking for alignment restrictions on int32_t... no
checking size of MPIR_Bsend_data_t... 56
checking for gcc __asm__ and pentium cmpxchgl instruction... yes
checking for gcc __asm__ and AMD x86_64 cmpxchgq instruction... no
checking for gcc __asm__ and IA64 xchg4 instruction... no
checking for ANSI C header files... (cached) no
checking stdlib.h usability... yes
checking stdlib.h presence... yes
checking for stdlib.h... yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking sys/types.h usability... yes
checking sys/types.h presence... yes
checking for sys/types.h... yes
checking string.h usability... yes
checking string.h presence... yes
checking for string.h... yes
checking for inttypes.h... (cached) yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking for stddef.h... (cached) yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking unistd.h usability... yes
checking unistd.h presence... yes
checking for unistd.h... yes
checking endian.h usability... no
checking endian.h presence... no
checking for endian.h... no
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking for sys/uio.h... yes
checking for size_t... yes
checking for setitimer... yes
checking for alarm... yes
checking for vsnprintf... yes
checking for vsprintf... yes
checking whether vsnprintf needs a declaration... no
checking for strerror... yes
checking for strncasecmp... yes
checking for snprintf... yes
checking whether snprintf needs a declaration... no
checking for va_copy... yes
checking for variable argument list macro functionality... yes
checking valgrind.h usability... no
checking valgrind.h presence... no
checking for valgrind.h... no
checking memcheck.h usability... no
checking memcheck.h presence... no
checking for memcheck.h... no
checking valgrind/valgrind.h usability... no
checking valgrind/valgrind.h presence... no
checking for valgrind/valgrind.h... no
checking valgrind/memcheck.h usability... no
checking valgrind/memcheck.h presence... no
checking for valgrind/memcheck.h... no
checking for working alloca.h... yes
checking for alloca... yes
checking for strdup... yes
checking whether strdup needs a declaration... no
checking for mkstemp... yes
checking whether mkstemp needs a declaration... no
checking for fdopen... yes
checking whether fdopen needs a declaration... yes
checking for putenv... yes
checking whether putenv needs a declaration... no
checking for clock_gettime... no
checking for clock_getres... no
checking for gethrtime... yes
checking for gettimeofday... yes
checking that hrtime_t is properly defined for gethrtime... yes
checking for gethrtime... (cached) yes
sourcing /work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/setup_device
RUNNING SETUP_DEVICE FOR THE CH3 DEVICE
sourcing /work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/setup_channel
RUNNING SETUP_CHANNEL FOR THE NEMESIS CHANNEL
sourcing /work/mpich2/mpich2-1.2.1p1/src/mpid/common/locks/setup
RUNNING SETUP FOR THE PROCESS LOCKS MODULE
SPARC V9 inline spin locks supported...no
SPARC V8 inline spin locks supported...no
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking for fgrep... /usr/bin/fgrep
checking for pthread_key_create in -lpthread... yes
checking for pthread_yield... no
checking for pthread_key_create... yes
checking for pthread_cleanup_push... no
checking whether pthread_cleanup_push is available (may be a macro in pthread.h)... no
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE_NP... no
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE... yes
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK_NP... no
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK... yes
checking for sched_yield... no
checking for yield... yes
checking for usleep... yes
checking for sleep... yes
checking for select... yes
checking for getpid... yes
checking for sched_setaffinity... no
checking for sched_getaffinity... no
checking for bindprocessor... no
checking for thread_policy_set... no
configure: configuring subsystem in src/openpa
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... mkdir -p
checking for gawk... no
checking for mawk... no
checking for nawk... nawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking whether to enable assertions... yes
checking for grep that handles long lines and -e... /usr/sfw/bin/ggrep
checking for egrep... /usr/sfw/bin/ggrep -E
checking for ANSI C header files... yes
checking for sys/stat.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking atomic.h usability... yes
checking atomic.h presence... yes
checking for atomic.h... yes
checking intrin.h usability... no
checking intrin.h presence... no
checking for intrin.h... no
checking for stdint.h... (cached) yes
checking for pthread_create in -lpthread... yes
checking sched.h usability... yes
checking sched.h presence... yes
checking for sched.h... yes
checking if 100 threads can be run at once... yes
checking if compiler rejects bogus asm statements... yes
checking for support for gcc x86/x86_64 bit primitives... yes
checking for support for gcc x86 bit primitives for pre-Pentium 4... yes
checking for support for gcc ia64 primitives... no
checking for support for gcc PowerPC atomics... no
checking for support for gcc SiCortex atomics... no
checking for support for gcc atomic intrinsics... no
checking for support for Windows NT atomic intrinsics... no
checking for support for Sun atomic operations library... yes
checking whether to enable strict fairness checks... no
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating test/Makefile
config.status: creating openpa.pc
config.status: creating src/config.h
config.status: executing src/opa_config.h commands
config.status: creating src/opa_config.h - prefix OPA for src/config.h defines
config.status: executing depfiles commands
configure: configuring subsystem in src/mpid/ch3
RUNNING CONFIGURE FOR CH3 DEVICE
checking whether make sets CFLAGS... yes
16
checking for string.h... (cached) yes
checking for sys/types.h... (cached) yes
checking sys/uio.h usability... yes
checking sys/uio.h presence... yes
checking uuid/uuid.h usability... yes
checking uuid/uuid.h presence... yes
checking for uuid/uuid.h... yes
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking for unistd.h... (cached) yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking for net/if.h... yes
checking for pid_t... yes
checking for inet_pton... no
checking for gethostname... yes
checking whether gethostname needs a declaration... no
checking for CFUUIDCreate... no
checking for uuid_generate... no
checking for time... yes
checking whether CPP accepts variable length argument lists... yes
checking whether we can use struct ifconf... yes
config.status: creating util/Makefile
config.status: creating util/shm/Makefile
config.status: creating util/shmbase/Makefile
config.status: creating channels/Makefile
config.status: creating util/ftb/Makefile
config.status: creating localdefs
config.status: creating include/mpid_thread.h
config.status: creating include/mpidi_ch3_conf.h
copying ./../common/thread/mpid_thread_mpe.c to src/mpid_thread.c
=== configuring in channels/nemesis (/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis)
configure: running /bin/bash ./configure --disable-option-checking '--prefix=/usr/local/bin/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'CC=gcc' 'CFLAGS= -O2' 'LIBS= -lpthread' 'CPPFLAGS= -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' --cache-file=/dev/null --srcdir=.
RUNNING CONFIGURE FOR THE NEMESIS CHANNEL
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/sockio.h usability... yes
checking sys/sockio.h presence... yes
checking for sys/sockio.h... yes
checking sys/ipc.h usability... yes
checking sys/ipc.h presence... yes
checking for sys/ipc.h... yes
checking sys/shm.h usability... yes
checking sys/shm.h presence... yes
checking for sys/shm.h... yes
checking for netinet/in.h... yes
checking for rand... yes
checking for srand... yes
checking for OpenPA atomic primitive availability... yes
checking for mmap... yes
checking for munmap... yes
configure: Using a memory-mapped file for shared memory
checking whether struct hostent contains h_addr_list... yes
checking knem_io.h usability... no
checking knem_io.h presence... no
checking for knem_io.h... no
config.status: creating nemesis/Makefile
config.status: creating nemesis/src/Makefile
config.status: creating nemesis/utils/Makefile
config.status: creating nemesis/utils/replacements/Makefile
config.status: creating nemesis/utils/monitor/Makefile
config.status: creating nemesis/netmod/Makefile
config.status: creating nemesis/netmod/elan/Makefile
config.status: creating nemesis/netmod/gm/Makefile
config.status: creating nemesis/netmod/mx/Makefile
config.status: creating nemesis/netmod/tcp/Makefile
config.status: creating nemesis/netmod/ib/Makefile
config.status: creating nemesis/netmod/psm/Makefile
config.status: creating nemesis/netmod/newmad/Makefile
config.status: creating nemesis/netmod/none/Makefile
config.status: creating nemesis/include/mpid_nem_net_module_defs.h
config.status: creating nemesis/src/mpid_nem_net_array.c
config.status: creating include/mpidi_ch3i_nemesis_conf.h
configure: configuring subsystem in src/mpid/common/locks
configure: WARNING: unrecognized options: --with-atomic-primitives
RUNNING CONFIGURE FOR LOCKS
checking for mutex_init... yes
checking for compare_and_swap... no
checking for pthread_mutexattr_init... yes
checking for pthread_mutexattr_setpshared... yes
config.status: creating mpid_locksconf.h
config.status: mpid_locksconf.h is unchanged
configure: configuring subsystem in src/mpi/romio
Configuring with args --prefix=/usr/local/bin/mpich2-install --with-atomic-primitives=auto_allow_emulation
checking for architecture... i86pc
configure: WARNING: Unknown architecture ... proceeding anyway
ROMIO home directory is /work/mpich2/mpich2-1.2.1p1/src/mpi/romio
checking whether f77 accepts -g... no
checking for memalign... yes
checking Fortran external names
/work/mpich2/mpich2-1.2.1p1/src/mpi/romio/configure: f77: not found
configure: WARNING: Unable to test Fortran compiler.  Compiling a test
program failed to produce an object file
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking for u_char... yes
checking for u_short... yes
checking for u_int... yes
checking for u_long... yes
checking sys/attr.h usability... no
checking sys/attr.h presence... no
checking for sys/attr.h... no
checking for int large enough for pointers... yes
Overriding Array test for MPICH2
checking for weak symbol support... pragma weak
checking that weak symbols are visible to other files... yes
checking that the compiler correctly implements weak symbols... yes
checking whether struct flock compatible with MPI_Offset... yes
checking for pvfs2-config... notfound
checking configured file systems... testfs ufs nfs
configure: WARNING: File locks may not work with NFS.  See the Installation and
users manual for instructions on testing and if necessary fixing this
checking for library containing aio_write... -lrt
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking if aio.h exists and can be compiled... yes
checking if sys/aio.h exists and can be compiled... yes
checking whether aio routines can be used... yes
checking for obsolete two-argument aio_write... no
checking for obsolete two-argument aio_suspend... no
checking for aio_fildes member of aiocb structure... yes
checking for aio_whence member of aiocb structure... no
checking for aio_handle member of aiocb structure... no
checking for aio_reqprio member of aiocb structure... yes
checking for aio_sigevent member of aiocb structure... yes
checking sys/vfs.h usability... yes
checking sys/vfs.h presence... yes
checking for sys/vfs.h... yes
checking sys/mount.h usability... yes
checking sys/mount.h presence... yes
checking for sys/mount.h... yes
checking sys/statvfs.h usability... yes
checking sys/statvfs.h presence... yes
checking for sys/statvfs.h... yes
checking whether struct statfs properly defined... no
checking for f_fstypename member of statfs structure... no
checking for sys/stat.h... (cached) yes
checking for stat... yes
checking for st_fstype member of stat structure... no
checking for sys/statvfs.h... (cached) yes
checking for sys/vfs.h... (cached) yes
checking for statvfs... yes
checking for f_basetype member of statvfs structure... yes
checking for large file defines... yes
checking whether off64_t is an scalar type... yes
checking for lstat... yes
checking whether lstat needs a declaration... yes
checking for readlink... yes
checking whether readlink needs a declaration... no
checking for fsync... yes
checking whether fsync needs a declaration... no
checking for ftruncate... yes
checking whether ftruncate needs a declaration... no
checking for lseek64... yes
checking whether lseek64 needs a declaration... no
setting SYSDEP_INC to
setting CC to gcc
setting F77 to :
setting TEST_CC to /work/mpich2/mpich2-1.2.1p1/bin/mpicc
setting TEST_F77 to /work/mpich2/mpich2-1.2.1p1/bin/mpif77
setting CFLAGS to  -O2  -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64
setting USER_CFLAGS to
setting USER_FFLAGS to
config.status: creating mpi-io/Makefile
config.status: creating mpi2-other/info/Makefile
config.status: creating mpi2-other/array/Makefile
config.status: creating adio/common/Makefile
config.status: creating test/misc.c
config.status: creating test/large_file.c
config.status: creating test/runtests
config.status: creating test-internal/Makefile
config.status: creating util/romioinstall
config.status: creating include/mpio.h
config.status: creating include/mpiof.h
config.status: creating adio/ad_nfs/Makefile
config.status: creating adio/ad_ufs/Makefile
config.status: creating adio/ad_bgl/Makefile
config.status: creating adio/ad_bglockless/Makefile
config.status: creating adio/ad_panfs/Makefile
config.status: creating adio/ad_xfs/Makefile
config.status: creating adio/ad_sfs/Makefile
config.status: creating adio/ad_pfs/Makefile
config.status: creating adio/ad_testfs/Makefile
config.status: creating adio/ad_pvfs/Makefile
config.status: creating adio/ad_pvfs2/Makefile
config.status: creating adio/ad_gridftp/Makefile
config.status: creating adio/ad_lustre/Makefile
config.status: creating adio/ad_zoidfs/Makefile
config.status: creating mpi-io/fortran/Makefile
config.status: creating mpi2-other/info/fortran/Makefile
config.status: creating mpi2-other/array/fortran/Makefile
config.status: creating test/fmisc.f
config.status: creating test/fcoll_test.f
config.status: creating test/pfcoll_test.f
config.status: creating test/fperf.f
config.status: creating mpi-io/glue/mpich2/Makefile
config.status: creating mpi-io/glue/mpich1/Makefile
config.status: creating mpi-io/glue/default/Makefile
config.status: creating common/dataloop/Makefile
config.status: creating adio/include/romioconf.h
configure: configuring subsystem in src/pmi/simple
RUNNING CONFIGURE FOR THE SIMPLE PMI
checking for stdlib.h... (cached) yes
checking for strings.h... (cached) yes
checking for sys/socket.h... (cached) yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking netinet/tcp.h usability... yes
checking netinet/tcp.h presence... yes
checking for netinet/tcp.h... yes
checking sys/un.h usability... yes
checking sys/un.h presence... yes
checking for sys/un.h... yes
checking for library containing socket... -lsocket
checking for library containing gethostbyname... -lnsl
checking for socket... yes
checking for setsockopt... yes
checking for gethostbyname... yes
checking whether socklen_t is defined (in sys/socket.h if present)... yes
config.status: creating pmiconf.h
configure: configuring subsystem in src/pm/mpd
checking whether ln -s works... yes
checking for a BSD-compatible install... ../../../confdb/install-sh -c
checking whether install ../../../confdb/install-sh -c works... yes
Using INSTALL=../../../confdb/install-sh -c
checking for totalview... no
checking for python2.6... no
checking for python2.5... no
checking for python2.4... python2.4
checking for python2.3... python2.3
checking for python2.2... no
checking for python2... no
checking for python... python
checking that python2.4 is a valid python version... yes
checking that the cPickle module is available for python2.4... yes
checking for library containing socket... none required
checking for sys/wait.h that is POSIX.1 compatible... yes
config.status: creating mpdconf.h
configure: configuring subsystem in src/pm/hydra
checking for a BSD-compatible install... mpl/confdb/install-sh -c
checking build system type... i386-pc-solaris2.10
checking host system type... i386-pc-solaris2.10
checking for a sed that does not truncate output... /usr/bin/sed
checking for fgrep... /usr/sfw/bin/ggrep -F
checking for ld used by gcc... /usr/ccs/bin/ld
checking if the linker (/usr/ccs/bin/ld) is GNU ld... no
checking for BSD- or MS-compatible name lister (nm)... /usr/ccs/bin/nm -p
checking the name lister (/usr/ccs/bin/nm -p) interface... BSD nm
checking the maximum length of command line arguments... 786240
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... no
checking for /usr/ccs/bin/ld option to reload object files... -r
checking for objdump... no
checking how to recognize dependent libraries... pass_all
checking for strip... strip
checking command to parse /usr/ccs/bin/nm -p output from gcc object... ok
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... no
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/ccs/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... yes
checking dynamic linker characteristics... solaris2.10 ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... no
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for doxygen... no
checking for socket in -lsocket... yes
checking for gethostbyname in -lnsl... yes
checking for sigaction... yes
checking for signal... yes
checking for alloca... no
checking for unsetenv... yes
checking for strsignal... yes
checking for putenv... (cached) yes
checking for environ in unistd.h... no
checking for manually declared extern environ... yes
checking boot-strap server... ssh,rsh,fork,slurm
checking communication subsystem... none
checking resource management kernel... dummy,pbs
checking process manager... pmiserv
checking user interface... mpiexec
checking debugging support... no
checking warnings... no
checking process binding library... plpa
checking if plpa works correctly... no
checking checkpointing library... none
checking whether the compiler allows __VA_ARGS__... yes
checking for strsignal... (cached) yes
checking whether strsignal needs a declaration... no
checking for sigaction... (cached) yes
checking for signal... (cached) yes
checking for sigset... yes
checking for struct sigaction and sa_handler... yes
config.status: creating tools/bootstrap/src/bsci_init.c
config.status: creating tools/bootstrap/include/bsci.h
config.status: creating rmk/src/rmki_init.c
config.status: creating rmk/include/rmki.h
config.status: creating css/src/cssi_init.c
config.status: creating css/include/cssi.h
config.status: creating hydra-doxygen.cfg
config.status: creating include/hydra_config.h
config.status: executing libtool commands
=== configuring in ../../mpl (/work/mpich2/mpich2-1.2.1p1/src/pm/hydra/../../mpl)
configure: running /bin/bash ./configure --disable-option-checking '--prefix=/usr/local/bin/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   -lnsl -lsocket ' 'CPPFLAGS= -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' --cache-file=/dev/null --srcdir=.
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
config.status: creating include/config.h
config.status: executing include/mplconfig.h commands
config.status: creating include/mplconfig.h - prefix MPL for include/config.h defines
configure: configuring subsystem in src/pm/gforker
RUNNING CONFIGURE FOR THE GFORKER PM
checking for setsid... yes
checking for isatty... yes
checking for getsid... yes
checking for library containing socketpair... none required
checking sys/ptrace.h usability... no
checking sys/ptrace.h presence... no
checking for sys/ptrace.h... no
checking for struct sigaction... yes
checking wait.h usability... yes
checking wait.h presence... yes
checking for wait.h... yes
config.status: creating forkerconf.h
=== configuring in ../util (/work/mpich2/mpich2-1.2.1p1/src/pm/gforker/../util)
RUNNING CONFIGURE FOR THE PM UTILITIES
checking for strtol... yes
checking whether getsid is prototyped in unistd.h... yes
checking for cygwin1.dll in /bin... yes
checking for extern environ in runtime... yes
checking for ANSI C header files... (cached) yes
checking whether struct iovec is defined in sys/uio.h... yes
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking whether FD_ZERO works... yes
config.status: creating pmutilconf.h
configure: configuring subsystem in src/mpe2
Configuring MPE Profiling System with  '--prefix=/usr/local/bin/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/work/mpich2/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/work/mpich2/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   -lnsl -lsocket ' 'CPPFLAGS= -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS='
checking for current directory name... /work/mpich2/mpich2-1.2.1p1/src/mpe2
checking gnumake... no
checking BSD 4.4 make... no - whew
checking OSF V3 make... no
This MPE build is part of the MPICH2 build
checking for leftover Makefiles in subpackages ... none
checking whether MPI_CC has been set ... /work/mpich2/mpich2-1.2.1p1/bin/mpicc
checking whether MPI_F77 has been set ... /work/mpich2/mpich2-1.2.1p1/bin/mpif77
checking for a BSD-compatible install... /work/mpich2/mpich2-1.2.1p1/src/mpe2/install-sh -c
config.status: creating sbin/mpetestlink
config.status: creating sbin/mpetestexec
config.status: creating sbin/mpetestexeclog
config.status: creating sbin/mpeinstall
config.status: creating sbin/mpecheckinstall
config.status: WARNING:  'sbin/mpecheckinstall.in' seems to ignore the --datarootdir setting
config.status: creating sbin/mpecheckbuild
config.status: creating etc/mpe_help.conf
config.status: creating etc/mpe_f77env.conf
config.status: creating mpe_conf.h
=== configuring in src/misc (/work/mpich2/mpich2-1.2.1p1/src/mpe2/src/misc)
configure: running /bin/bash ./configure --disable-option-checking '--prefix=/usr/local/bin/mpich2-install'  '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/work/mpich2/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/work/mpich2/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   -lnsl -lsocket ' 'CPPFLAGS= -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' --cache-file=/dev/null --srcdir=.
Configuring MPE Miscellaneous Library with  '--disable-option-checking' '--prefix=/usr/local/bin/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/work/mpich2/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/work/mpich2/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   -lnsl -lsocket ' 'CPPFLAGS= -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /work/mpich2/mpich2-1.2.1p1/src/mpe2/src/misc
checking whether gcc and cc understand -c and -o together... yes
checking for dbx... no
checking for gdb... no
checking for sysinfo... yes
checking for uname... yes
checking sys/systeminfo.h usability... yes
checking sys/systeminfo.h presence... yes
checking for sys/systeminfo.h... yes
checking for sighandler_t... no
checking for kill... yes
checking whether kill needs a declaration... no
config.status: creating src/dbxerr.c
config.status: creating mpe_misc_conf.h
=== configuring in src/callstack (/work/mpich2/mpich2-1.2.1p1/src/mpe2/src/callstack)
Configuring MPE CallStack Library with  '--disable-option-checking' '--prefix=/usr/local/bin/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/work/mpich2/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/work/mpich2/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   -lnsl -lsocket ' 'CPPFLAGS= -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /work/mpich2/mpich2-1.2.1p1/src/mpe2/src/callstack
checking execinfo.h usability... no
checking execinfo.h presence... no
checking for execinfo.h... no
checking ucontext.h usability... yes
checking ucontext.h presence... yes
checking for ucontext.h... yes
checking whether <ucontext.h> defines printstack() ... yes
checking whether printstack() can be linked ... yes
checking whether fdopen needs a declaration... no
config.status: creating include/mpe_callstack.h
config.status: creating etc/mpe_callstack_ldflags.conf
config.status: creating mpe_callstack_conf.h
=== configuring in src/logging (/work/mpich2/mpich2-1.2.1p1/src/mpe2/src/logging)
Configuring MPE Logging Library and Tools with  '--disable-option-checking' '--prefix=/usr/local/bin/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/work/mpich2/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/work/mpich2/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   -lnsl -lsocket ' 'CPPFLAGS= -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /work/mpich2/mpich2-1.2.1p1/src/mpe2/src/logging
checking for header that defines C99 integer types, intXX_t ... <stdint.h>
checking whether <inttypes.h> defines the PRIdXX macros ... yes
checking if <stdint.h> can be behind system headers ... yes
checking for address-sized integer ... CLOG_int32_t
checking for srand48... yes
checking whether srand48 needs a declaration... no
checking for lrand48... yes
checking whether lrand48 needs a declaration... no
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... 64
checking for O_LARGEFILE for open() ... yes
checking for O_BINARY for open() ... no
checking for pthread_mutex_lock in -lpthread... yes
config.status: creating include/clog_inttypes.h
config.status: creating include/mpi_null.h
config.status: creating include/mpe_log_thread.h
config.status: creating etc/mpe_log.conf
config.status: creating etc/mpe_nolog.conf
config.status: creating etc/mpe_log_postlib.conf
config.status: creating mpe_logging_conf.h
=== configuring in src/wrappers (/work/mpich2/mpich2-1.2.1p1/src/mpe2/src/wrappers)
Configuring MPE Wrapper Libraries For MPI with  '--disable-option-checking' '--prefix=/usr/local/bin/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/work/mpich2/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/work/mpich2/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   -lnsl -lsocket ' 'CPPFLAGS= -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /work/mpich2/mpich2-1.2.1p1/src/mpe2/src/wrappers
checking for stdarg is correct... yes
checking if compiler accepts prototypes ... yes
checking for safe PMPI invocations ... no
config.status: creating etc/mpe_mpilog.conf
config.status: creating etc/mpe_mpitrace.conf
config.status: creating mpe_wrappers_conf.h
=== configuring in src/graphics (/work/mpich2/mpich2-1.2.1p1/src/mpe2/src/graphics)
Configuring MPE X Graphics Library with  '--disable-option-checking' '--prefix=/usr/local/bin/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/work/mpich2/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/work/mpich2/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   -lnsl -lsocket ' 'CPPFLAGS= -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /work/mpich2/mpich2-1.2.1p1/src/mpe2/src/graphics
checking for X... libraries /usr/openwin/lib, headers /usr/openwin/include
checking for long pointer... no
checking for system... yes
config.status: creating contrib/life/Makefile
config.status: creating contrib/mandel/Makefile
config.status: creating contrib/mastermind/Makefile
config.status: creating contrib/test/Makefile
config.status: creating etc/mpe_mpianim.conf
config.status: creating etc/mpe_graphics.conf
config.status: creating mpe_graphics_conf.h
=== configuring in src/collchk (/work/mpich2/mpich2-1.2.1p1/src/mpe2/src/collchk)
Configuring MPE Collective and Datatype Checking Library with  '--disable-option-checking' '--prefix=/usr/local/bin/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/work/mpich2/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/work/mpich2/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   -lnsl -lsocket ' 'CPPFLAGS= -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /work/mpich2/mpich2-1.2.1p1/src/mpe2/src/collchk
config.status: creating etc/mpe_mpicheck.conf
config.status: creating mpe_collchk_conf.h
=== configuring in src/slog2sdk (/work/mpich2/mpich2-1.2.1p1/src/mpe2/src/slog2sdk)
checking for current directory name... /work/mpich2/mpich2-1.2.1p1/src/mpe2/src/slog2sdk
Configuring SLOG2SDK with  '--disable-option-checking' '--prefix=/usr/local/bin/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/work/mpich2/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/work/mpich2/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   -lnsl -lsocket ' 'CPPFLAGS= -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' '--cache-file=/dev/null' '--srcdir=.'
checking for a BSD-compatible install... /work/mpich2/mpich2-1.2.1p1/src/mpe2/src/slog2sdk/install-sh -c
checking if CLASSPATH is set... no, good to go
checking for java in user's PATH... found /usr/bin/java
checking if /usr/bin/java runs simple java class... yes
checking if /usr/bin/java runs simple jar file... yes
checking if /usr/bin/java runs non-GUI tool... yes
checking if /usr/bin/java runs simple Swing class... yes
checking if /usr/bin/java runs simple Swing jar file... yes
checking for Java version... java full version "1.5.0_20-b02", i.e. Java 2 SDK
checking for cygpath... no
creating /work/mpich2/mpich2-1.2.1p1/src/mpe2/src/slog2sdk/share
creating /work/mpich2/mpich2-1.2.1p1/src/mpe2/src/slog2sdk/share/logfiles
creating sample logfiles from source
config.status: creating sbin/install-package
config.status: creating bin/slog2print
config.status: creating bin/slog2navigator
config.status: creating bin/slog2filter
config.status: creating bin/slog2updater
config.status: creating bin/logconvertor
config.status: creating bin/jumpshot
config.status: creating bin/clogprint
config.status: creating bin/clogTOslog2
config.status: creating bin/clog2print
config.status: creating bin/clog2TOslog2
=== configuring in trace_rlog (/work/mpich2/mpich2-1.2.1p1/src/mpe2/src/slog2sdk/trace_rlog)
checking for current directory name... /work/mpich2/mpich2-1.2.1p1/src/mpe2/src/slog2sdk/trace_rlog
Configuring TRACE_RLOG implementation with  '--disable-option-checking' '--prefix=/usr/local/bin/mpich2-install' '--with-atomic-primitives=auto_allow_emulation' 'MPI_CC=/work/mpich2/mpich2-1.2.1p1/bin/mpicc' 'MPI_F77=/work/mpich2/mpich2-1.2.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS=' 'LIBS= -lpthread   -lrt   -lnsl -lsocket ' 'CPPFLAGS= -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS' 'F77=' 'FFLAGS=' '--cache-file=/dev/null' '--srcdir=.'
checking size of __int64... 0
checking for sed... sed
checking for a sed that does not truncate output... sed
checking whether to build static libraries... no
checking for malloc in -lefence... no
checking for strstr... yes
checking target system type... i386-pc-solaris2.10
checking for javah in user's PATH... found /usr/bin/javah
checking if /usr exists... yes
checking for <jni.h> include flag... no
checking for javah in user's PATH... found /usr/java/bin/javah
checking if /usr/java exists... yes
checking for <jni.h> include flag... found -I/usr/java/include -I/usr/java/include/solaris
checking for <jni.h> usability... yes
checking for a BSD-compatible install... /work/mpich2/mpich2-1.2.1p1/src/mpe2/src/slog2sdk/trace_rlog/install-sh -c
checking for ranlib... (cached) ranlib
creating directory /work/mpich2/mpich2-1.2.1p1/src/mpe2/src/slog2sdk/trace_rlog/lib
creating /work/mpich2/mpich2-1.2.1p1/src/mpe2/src/slog2sdk/trace_rlog/share
creating /work/mpich2/mpich2-1.2.1p1/src/mpe2/src/slog2sdk/trace_rlog/share/logfiles
config.status: creating bin/traceprint
config.status: creating bin/traceTOslog2
config.status: creating trace_impl.h
SLOG2SDK:  "trace_rlog" have been configured
MPE2:  "src/misc" "src/callstack" "src/logging" "src/wrappers" "src/graphics" "src/collchk" "src/slog2sdk" have been configured
checking size of OPA_ptr_t... 4
configure: WARNING: Could not define Fortran MPI datatypes for C
checking the sizeof MPI_Offset... 8
config.status: creating src/include/Makefile
config.status: creating src/include/mpich2info.h
config.status: creating mpich2-doxygen
config.status: creating src/include/mpichtimer.h
config.status: creating src/binding/Makefile
config.status: creating src/binding/cxx/Makefile
config.status: creating src/binding/cxx/mpicxx.h
config.status: creating src/binding/f77/Makefile
config.status: creating src/binding/f77/mpif.h
config.status: creating src/binding/f77/setbotf.f
config.status: creating src/binding/f90/Makefile
config.status: creating src/binding/f90/mpi_sizeofs.f90
config.status: creating src/packaging/Makefile
config.status: creating src/packaging/pkgconfig/mpich2-ch3.pc
config.status: creating src/packaging/pkgconfig/Makefile
config.status: creating src/packaging/envmods/mpich2.module
config.status: WARNING:  'src/packaging/envmods/mpich2.module.in' seems to ignore the --datarootdir setting
config.status: creating src/packaging/envmods/Makefile
config.status: creating src/env/mpixxx_opts.conf
config.status: creating src/env/mpicc
config.status: creating src/env/mpicc.conf
config.status: creating src/env/mpicc.bash
config.status: creating src/env/mpicxx
config.status: creating src/env/mpicxx.conf
config.status: creating src/env/mpicxx.bash
config.status: creating src/env/mpif77
config.status: creating src/env/mpif77.conf
config.status: creating src/env/mpif77.bash
config.status: creating src/env/mpif90
config.status: creating src/env/mpif90.conf
config.status: creating src/env/mpif90.bash
config.status: creating src/env/parkill
config.status: creating src/env/Makefile
config.status: creating src/util/createshlib
config.status: creating src/mpi/Makefile
config.status: creating src/mpi/attr/Makefile
config.status: creating src/mpi/coll/Makefile
config.status: creating src/mpi/comm/Makefile
config.status: creating src/mpi/datatype/Makefile
config.status: creating src/mpi/debugger/Makefile
config.status: creating src/mpi/errhan/Makefile
config.status: creating src/mpi/group/Makefile
config.status: creating src/mpi/init/Makefile
config.status: creating src/mpi/misc/Makefile
config.status: creating src/mpi/pt2pt/Makefile
config.status: creating src/mpi/rma/Makefile
config.status: creating src/mpi/spawn/Makefile
config.status: creating src/mpi/timer/Makefile
config.status: creating src/mpi/topo/Makefile
config.status: creating src/mpid/Makefile
config.status: creating src/mpid/common/Makefile
config.status: creating src/mpid/common/datatype/Makefile
config.status: creating src/mpid/common/datatype/dataloop/Makefile
config.status: creating src/pm/Makefile
config.status: creating src/pmi/Makefile
config.status: creating src/pmi/simple/Makefile
config.status: creating src/nameserv/Makefile
config.status: creating src/nameserv/file/Makefile
config.status: creating src/nameserv/mpd/Makefile
config.status: creating src/nameserv/pmi/Makefile
config.status: creating src/nameserv/test/Makefile
config.status: creating src/util/Makefile
config.status: creating src/util/info/Makefile
config.status: creating src/util/instrm/Makefile
config.status: creating src/util/thread/Makefile
config.status: creating src/util/mem/Makefile
config.status: creating src/util/msgs/Makefile
config.status: creating src/util/param/Makefile
config.status: creating src/util/dbg/Makefile
config.status: creating src/util/dbg/getfuncstack
config.status: creating src/util/osserv/Makefile
config.status: creating src/util/procmap/Makefile
config.status: creating src/util/other/Makefile
config.status: creating src/include/mpi.h
config.status: creating test/util/Makefile
config.status: creating test/basic/Makefile
config.status: creating test/commands/Makefile
config.status: creating test/commands/cmdtests
config.status: creating test/mpid/Makefile
config.status: creating test/mpid/ch3/Makefile
config.status: creating test/util/timer/Makefile
config.status: creating examples/Makefile
config.status: creating examples/f77/Makefile
config.status: creating examples/f90/Makefile
config.status: creating examples/cxx/Makefile
config.status: creating src/util/logging/Makefile
config.status: creating src/util/logging/common/Makefile
config.status: creating doc/Makefile
config.status: creating doc/mansrc/Makefile
config.status: creating doc/mansrc/createhtmlindex
config.status: creating doc/refman/Makefile
config.status: creating doc/installguide/Makefile
config.status: creating doc/userguide/Makefile
config.status: creating doc/logging/Makefile
config.status: creating doc/design/Makefile
config.status: creating doc/smpd/Makefile
config.status: creating doc/windev/Makefile
config.status: creating src/include/mpichconf.h
config.status: executing default-4 commands
config.status: executing default-5 commands
config.status: executing default-6 commands
config.status: executing default-7 commands
config.status: executing default-8 commands
Updating dependency directories .deps
config.status: executing default-9 commands
config.status: executing default-10 commands
config.status: executing default-11 commands
config.status: executing default-12 commands
config.status: executing default-13 commands
=== configuring in test/mpi (/work/mpich2/mpich2-1.2.1p1/test/mpi)
configure: running /bin/bash ./configure --disable-option-checking '--prefix=/usr/local/bin/mpich2-install'  --cache-file=/dev/null --srcdir=.
RUNNING CONFIGURE FOR MPI TESTS
checking for memory.h... (cached) yes
checking for pthread_create... yes
checking for pthread_barrier_init... yes
checking for pthread_barrier_wait... yes
Configuring tests for MPICH2
checking whether struct hostent contains h_addr_list... no
configure: WARNING: Selecting integer*8 as the Fortran type for MPI_Offset
configure: WARNING: Selecting integer as the Fortran type for MPI_Aint
checking whether MPI_2DOUBLE_COMPLEX is available... no
checking for C integer type of address size... int
config.status: creating maint/testmerge
config.status: creating runtests
config.status: creating basic/Makefile
config.status: creating attr/Makefile
config.status: creating coll/Makefile
config.status: creating comm/Makefile
config.status: creating datatype/Makefile
config.status: creating errhan/Makefile
config.status: creating group/Makefile
config.status: creating info/Makefile
config.status: creating init/Makefile
config.status: creating pt2pt/Makefile
config.status: creating rma/Makefile
config.status: creating spawn/Makefile
config.status: creating topo/Makefile
config.status: creating io/Makefile
config.status: creating f77/Makefile
config.status: creating f77/attr/Makefile
config.status: creating f77/attr/attraints.h
config.status: creating f77/pt2pt/attr1aints.h
config.status: creating f77/ext/add1size.h
config.status: creating f77/datatype/Makefile
config.status: creating f77/datatype/typeaints.h
config.status: creating f77/util/Makefile
config.status: creating f77/coll/Makefile
config.status: creating f77/comm/Makefile
config.status: creating f77/topo/Makefile
config.status: creating f77/init/Makefile
config.status: creating f77/rma/addsize.h
config.status: creating f77/pt2pt/Makefile
config.status: creating f77/info/Makefile
config.status: creating f77/spawn/Makefile
config.status: creating f77/spawn/type1aint.h
config.status: creating f77/rma/Makefile
config.status: creating f77/ext/Makefile
config.status: creating f77/ext/testlist
config.status: creating f77/io/Makefile
config.status: creating f77/io/iooffset.h
config.status: creating f77/io/iodisp.h
config.status: creating f77/io/ioaint.h
config.status: creating f90/Makefile
config.status: creating f90/attr/Makefile
config.status: creating f90/datatype/Makefile
config.status: creating f90/f90types/Makefile
config.status: creating f90/util/Makefile
config.status: creating f90/coll/Makefile
config.status: creating f90/comm/Makefile
config.status: creating f90/topo/Makefile
config.status: creating f90/init/Makefile
config.status: creating f90/pt2pt/Makefile
config.status: creating f90/rma/Makefile
config.status: creating f90/info/Makefile
config.status: creating f90/spawn/Makefile
config.status: creating f90/timer/Makefile
config.status: creating f90/ext/Makefile
config.status: creating f90/ext/testlist
config.status: creating f90/io/Makefile
config.status: creating f90/misc/Makefile
config.status: creating cxx/Makefile
config.status: creating cxx/util/Makefile
config.status: creating cxx/attr/Makefile
config.status: creating cxx/pt2pt/Makefile
config.status: creating cxx/comm/Makefile
config.status: creating cxx/coll/Makefile
config.status: creating cxx/info/Makefile
config.status: creating cxx/datatype/Makefile
config.status: creating cxx/io/Makefile
config.status: creating cxx/init/Makefile
config.status: creating cxx/rma/Makefile
config.status: creating cxx/spawn/Makefile
config.status: creating threads/Makefile
config.status: creating threads/pt2pt/Makefile
config.status: creating threads/util/Makefile
config.status: creating threads/comm/Makefile
config.status: creating threads/init/Makefile
config.status: creating threads/spawn/Makefile
config.status: creating errors/Makefile
config.status: creating errors/attr/Makefile
config.status: creating errors/basic/Makefile
config.status: creating errors/coll/Makefile
config.status: creating errors/comm/Makefile
config.status: creating errors/faults/Makefile
config.status: creating errors/group/Makefile
config.status: creating errors/pt2pt/Makefile
config.status: creating errors/rma/Makefile
config.status: creating errors/spawn/Makefile
config.status: creating errors/topo/Makefile
config.status: creating errors/io/Makefile
config.status: creating errors/cxx/Makefile
config.status: creating errors/cxx/errhan/Makefile
config.status: creating errors/cxx/io/Makefile
config.status: creating errors/f77/Makefile
config.status: creating errors/f90/Makefile
config.status: creating manual/Makefile
config.status: creating manual/manyconnect
config.status: creating perf/Makefile
config.status: creating testlist
config.status: creating cxx/testlist
config.status: creating f77/testlist
config.status: creating f90/testlist
config.status: creating threads/testlist
config.status: creating errors/testlist
config.status: creating errors/cxx/testlist
Beginning make
Using variables CC='gcc' CFLAGS=' -O2' LDFLAGS='' AR='ar' FC='' F90='' FFLAGS='' F90FLAGS='' CXX='c++' CPPFLAGS=' -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS  -I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/include -I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/include -I/work/mpich2/mpich2-1.2.1p1/src/mpid/common/datatype -I/work/mpich2/mpich2-1.2.1p1/src/mpid/common/datatype -I/work/mpich2/mpich2-1.2.1p1/src/mpid/common/locks -I/work/mpich2/mpich2-1.2.1p1/src/mpid/common/locks -I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/include -I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/include -I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/work/mpich2/mpich2-1.2.1p1/src/mpid/common/locks -I/work/mpich2/mpich2-1.2.1p1/src/mpid/common/locks -I/work/mpich2/mpich2-1.2.1p1/src/util/wrappers -I/work/mpich2/mpich2-1.2.1p1/src/util/wrappers'
make all-local
make clean && cd test && make clean
make cleanlibs
rm -f lib/libmpich.a lib/libpmpich.a
rm -f lib/libmpichcxx.a
rm -f lib/libfmpich.a lib/libmpichf90.a
rm -f lib/libmpich.so*
rm -f lib/libpmpich.so*
rm -f lib/libmpichcxx.so*
rm -f lib/libfmpich.so*
rm -f lib/libmpichf90.so*
rm -f lib/libmpichf90.*.so*
rm -f lib/libmpich.*.so*
rm -f lib/libpmpich.*.so*
rm -f lib/libmpichcxx.*.so*
rm -f lib/libfmpich.*.so*
rm -f lib/libmpich.la* lib/libpmpich.la*
rm -f lib/libmpichf90.la*
rm -f lib/libmpichcxx.la*
rm -f lib/libfmpich.la*
for dir in  src/openpa src examples - ; do \
	if [ "$dir" = "-" ] ; then break ; fi ; \
	(cd $dir && make clean ) ; done
Making clean in test
test -z "sanity test_primitives  test_barriers" || rm -f sanity test_primitives  test_barriers
rm -f *.o
Making clean in src
test -z "libopa.a" || rm -f libopa.a
rm -f *.o
Making clean in .
for dir in mpid mpi util nameserv binding env packaging mpe2 pmi pm - ; do \
for dir in common ch3 - ; do \
	if [ "$dir" = "mpe2" ] ; then continue ; fi ;\
(cd locks && make clean )
(cd datatype && make clean )
(cd dataloop && make clean )
for dir in channels src util ; do \
for dir in nemesis - ; do \
(cd nemesis && make clean )
(cd src && make clean )
(cd netmod && make clean )
for dir in tcp - ; do \
(cd utils && make clean )
(cd monitor && make clean )
(cd replacements && make clean )
for dir in   - ; do \
for dir in attr coll comm datatype errhan group init misc pt2pt rma spawn timer topo romio  - ; do \
cleaning directory mpi-io
cleaning directory adio/common
cleaning directory mpi-io/glue/mpich2
cleaning directory adio/ad_testfs
cleaning directory adio/ad_ufs
cleaning directory adio/ad_nfs
cleaning directory test-internal
rm -f .P* PI* *.o
rm -f file_realms_test io_bounds_test heap_test
rm -f .P* PI* *.o
rm -f simple perf async coll_test coll_perf misc file_info excl large_array  atomicity noncontig i_noncontig noncontig_coll split_coll shared_fp  large_file psimple error status noncontig_coll2 aggregation1 aggregation2  async-multiple ordered_fp hindexed fcoll_test fperf fmisc pfcoll_test
for dir in mem info msgs instrm thread dbg param osserv procmap other  - ; do \
for dir in mpd - ; do \
for dir in  cxx - ; do \
(cd pkgconfig && make clean )
(cd envmods && make clean )
rm -f /work/mpich2/mpich2-1.2.1p1/src/mpe2/lib/lib*
rm -f /work/mpich2/mpich2-1.2.1p1/src/mpe2/lib/*.jar
rm -f /work/mpich2/mpich2-1.2.1p1/src/mpe2/lib/*.o
for dir in simple - ; do \
for dir in mpd  hydra gforker - ; do \
Making clean in ../../mpl
test -z "libmpl.a" || rm -f libmpl.a
rm -f *.o
Making clean in .
 rm -f pmi_proxy mpiexec
rm -rf .libs _libs
test -z "libhydra.a libpm.a libui.a" || rm -f libhydra.a libpm.a libui.a
rm -f *.o
rm -f *.lo
rm -f libmpiexec.a
for dir in mpi mpid util basic commands ; do \
rm -f summary.xml
for dir in util attr basic datatype coll comm errhan group info init pt2pt rma spawn topo io  cxx threads errors manual perf - ; do \
rm -f summary.xml
rm -f summary.xml
rm -f summary.xml
rm -f summary.xml
rm -f summary.xml
rm -f summary.xml
rm -f summary.xml
for dir in util attr pt2pt init info comm coll datatype io rma spawn ; do \
rm -f .iotest.txt.*
rm -f summary.xml
for dir in util pt2pt comm init spawn ; do \
for dir in attr coll comm group pt2pt rma spawn topo io  cxx basic faults - ; do \
rm -f summary.xml
(cd io && make clean )
(cd errhan && make clean )
rm -f summary.xml
(cd ch3 && make clean )
(cd timer && make clean )
rm -f err.txt out.log out.txt stdintest stdintest2 sdtiotest a.out
rm -f lib/newconfig
Making all in src
make  all-am
gcc -DHAVE_CONFIG_H -I.    -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS  -O2 -MT opa_primitives.o -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.o opa_primitives.c
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Po
gcc -DHAVE_CONFIG_H -I.    -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS  -O2 -MT opa_queue.o -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.o opa_queue.c
mv -f .deps/opa_queue.Tpo .deps/opa_queue.Po
rm -f libopa.a
ar cru libopa.a opa_primitives.o opa_queue.o
ranlib libopa.a
Making all in test
  CC              mpidu_process_locks.c
  AR cr ../../../../lib/libmpich.a mpidu_process_locks.o
  RANLIB          libmpich.a
date > .libstamp0
  CC              dataloop.c
/var/tmp//ccHcN5Kf.s: Assembler messages:
/var/tmp//ccHcN5Kf.s:395: Error: suffix or operands invalid for `mov'
/var/tmp//ccHcN5Kf.s:403: Error: suffix or operands invalid for `mov'
*** Error code 1
The following command caused the error:
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/work/mpich2/mpich2-1.2.1p1/src/include -I/work/mpich2/mpich2-1.2.1p1/src/include -O2  -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -I/work/mpich2/mpich2-1.2.1p1/src/openpa/src -DUSE_PROCESS_LOCKS  -I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/include -I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/include -I/work/mpich2/mpich2-1.2.1p1/src/mpid/common/datatype -I/work/mpich2/mpich2-1.2.1p1/src/mpid/common/datatype -I/work/mpich2/mpich2-1.2.1p1/src/mpid/common/locks -I/work/mpich2/mpich2-1.2.1p1/src/mpid/common/locks -I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/include -I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/include -I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/work/mpich2/mpich2-1.2.1p1/src/mpid/common/locks -I/work/mpich2/mpich2-1.2.1p1/src/mpid/common/locks -I/work/mpich2/mpich2-1.2.1p1/src/util/wrappers -I/work/mpich2/mpich2-1.2.1p1/src/util/wrappers -c dataloop.c
make: Fatal error: Command failed for target `dataloop.o'
Current working directory /work/mpich2/mpich2-1.2.1p1/src/mpid/common/datatype/dataloop
*** Error code 1
(cd dataloop && make all )
make: Fatal error: Command failed for target `all-redirect'
*** Error code 1
(cd datatype && make all )
*** Error code 1
(cd common && make all )
*** Error code 1
(cd mpid && make all )
*** Error code 1
(cd src && make all )
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100602/8b0546d9/attachment-0001.obj>
