[mpich-discuss] heterogeneous cluster setup
jayesh at mcs.anl.gov
Wed Jun 2 13:12:18 CDT 2010
Yes, you can run your MPI job with MPICH2 across windows and unix operating systems. However you cannot run your job across systems with different data models (eg: across 32-bit and 64-bit systems).
Since SMPD is the only process manager currently available on windows you should configure MPICH2 on unix with the smpd process manager (./configure ... --with-pm=smpd) and you should be good to go.
Let us know if you need any help.
(PS: The default channels on both unix and windows systems are nemesis from MPICH2 1.3a2 . You can also try the sock channel if the nemesis channel does not work for you. To try the sock channel on unix, ./configure ... --with-pm=smpd --with-device=ch3:sock, and on windows select the sock channel at runtime, mpiexec -n 2 -channel sock MYMPIPGM.exe)
Jayesh
----- Original Message -----
Sent: Wednesday, June 2, 2010 12:09:23 PM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] heterogeneous cluster setup
Hi all,
I have a question regarding the support for heterogeneous systems. Using
the latest MPICH version, is it possible to have a single MPI
application running across a cluster of mixed operating systems, say for
example Windows and Linux? If not, would you recommend and available
framework with such support?
Hicham
mpich-discuss mailing list
