[mpich-discuss] for help - using wmpiconfig
Jayesh Krishna jayesh at mcs.anl.gov
Thu Jul 15 18:41:44 CDT 2010
 Did you install the same version of MPICH2 on all the hosts ? Are you able to run an MPI job across the hosts (From command line type , mpiexec -n 2 -machinefile mf.txt hostname, where mf.txt contains the ipaddresses of the hosts)?
(PS: Copy your emails to mpich-discuss instead of mpich2-maint for now)
Jayesh
----- Original Message -----
To: "mpich2-maint" <mpich2-maint at mcs.anl.gov>
Sent: Wednesday, July 14, 2010 10:01:44 PM GMT -06:00 US/Canada Central
Subject: [mpich2-maint] for help
hello,
I have successfully installed mpich2-1.2.1p1-win-ia32.msi on my windows xp seystem, I added ";C:\Program Files\MPICH2\bin" to the Environment variables, also i used the adminstor account register in wmpiregister diolog box. but when i run the wmpiconfig and scan hosts , the hosts and versions displayed gray(failure), instead of gree, what should i do? thank you for help.
csuzmc,
Thursday,July 15,2010.
mpich2-maint mailing list
mpich2-maint at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/mpich2-maint
