[mpich-discuss] Kernel based SCTP stack for Windows
jayesh at mcs.anl.gov
Thu Jul 15 18:37:54 CDT 2010
I am currently on vacation and will be back to work next week. I can try out your stack next week and let you know the results.
You can also play around with "https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/maint/winbuild.wsf" which provides an interface to use the windows makefile to build MPICH2 (I use this script for testing MPICH2 builds with VS2008).
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Cc: mpich-discuss at mcs.anl.gov, penoff at cs.ubc.ca
Sent: Thursday, July 15, 2010 10:41:31 AM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] Kernel based SCTP stack for Windows
On 14 July 2010 02:01, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
> And you can copy mpich-discuss during your discussions. We can assist in integrating your stack with MPICH2 on windows.
To use SctpDrv you just need to point the include path at C:\Program
Files\SctpDrv\inc (it contains with ws2sctp.h and netinet/sctp.h) and
the library path at C:\Program Files\SctpDrv\lib, which contains
libsctp.a for cygwin applications and sctpsp.lib for native Windows
apps. The installer can be found at
http://www.bluestop.org/SctpDrv/releases/1.1.5/en-us/ , though
libsctp.a is missing and will be present in 1.1.6.
I've been trying to build mpich2 on Windows 7 x64 but have been
encountering some problems - I'm using Visual Studio 2010 so I don't
know if that's causing issues, but it seems mpl.h isn't in the include
path. I managed to work around earlier issues by trial and error, and
will create a patch to the README file (for example, winconfigure.wsf
should be run as "cscript winconfigure.wsf" under cygwin with
nodosfilewarning set - also, it seems the Windows HPC pack is
required, which isn't documented.
Is building using Visual C++ 2008 likely to work better?
Bruce Cran
> From: "Brad Penoff" <penoff at cs.ubc.ca>
> To: mpich-discuss at mcs.anl.gov
> Sent: Monday, July 12, 2010 2:53:04 AM GMT -06:00 US/Canada Central
> Greetings,
> I helped developed the ch3:sctp channel and try to maintain it. In my
> research, I also have some experience working with the BSD stack as
> well. I would love to try to make use of your port of that stack.
> Perhaps we could email off-list and work on a set of instructions I
> could add to the MPICH2 release notes? Admittedly though, I have very
> little experience with development in the Windows environment. Please
> feel free to contact me if this is of interest to you.
> Thanks,
> brad
> On Sat, Jul 10, 2010 at 3:52 PM, Bruce Cran <bruce.cran at gmail.com> wrote:
>> Hi,
>> I noticed that the release notes for mpich2
>> (https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/RELEASE_NOTES) state
>> that there's no known SCTP kernel driver for Windows. I've been
>> working on SctpDrv since late 2009, which is a port of the BSD stack
>> to Windows: the stack runs as a driver in kernel mode, with the SCTP
>> API provided as a library. More information can be found at
>> http://www.bluestop.org/SctpDrv/ .
>> Bruce Cran
>> mpich-discuss mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
