[mpich-discuss] unable to build mpich2 with romio
    Rajeev Thakur
    thakur at mcs.anl.gov
    Mon Jan 25 13:14:50 CST 2010
Are you using the MPICH2 1.2.1 tarball or the current version in the svn
trunk?
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Ryan Kroiss
> Sent: Friday, January 22, 2010 2:59 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] unable to build mpich2 with romio
> I'm having trouble building mpich2 with ROMIO enabled.  I
> need this so
> that I can work with IOFSL.  I've followed the instructions found at
> <https://trac.mcs.anl.gov/projects/iofsl/wiki/Building>.  I'm running
> automake version 1.11.1, autoconf version 2.63, and libtool version
> 2.2.6b.  I believe that I was able to run ./maint/updatefiles
> successfully (at least it completed without complaining).
> After running
> this, I'm trying to run the following command:  ./configure
> --enable-romio --with-file-system=ufs+zoidfs.  I get the
> following error
> though:
> /home/rrkroiss/libs/mpich2/src/mpl/configure: line 11066:
> syntax error
> near unexpected token `include/mplconfig.h,MPL'
> `AX_PREFIX_CONFIG_H(include/mplconfig.h,MPL)'
> configure: error: MPL configure failed
> Any help would be appreciated!
> Thanks,
> Ryan
> mpich-discuss mailing list
