[mpich-discuss] unable to build mpich2 with romio
Ryan Kroiss rrkroiss at lanl.gov
Fri Jan 22 14:58:31 CST 2010
I'm having trouble building mpich2 with ROMIO enabled.  I need this so
that I can work with IOFSL.  I've followed the instructions found at
<https://trac.mcs.anl.gov/projects/iofsl/wiki/Building>.  I'm running
automake version 1.11.1, autoconf version 2.63, and libtool version
2.2.6b.  I believe that I was able to run ./maint/updatefiles
successfully (at least it completed without complaining).  After running
this, I'm trying to run the following command:  ./configure
--enable-romio --with-file-system=ufs+zoidfs.  I get the following error
though:
/home/rrkroiss/libs/mpich2/src/mpl/configure: line 11066: syntax error
near unexpected token `include/mplconfig.h,MPL'
`AX_PREFIX_CONFIG_H(include/mplconfig.h,MPL)'
configure: error: MPL configure failed
Any help would be appreciated!
Ryan
