[mpich-discuss] unable to build mpich2 with romio
    Dave Goodell
    goodell at mcs.anl.gov
    Mon Jan 25 13:27:02 CST 2010
The AX_PREFIX_CONFIG_H macro isn't being expanded for some reason.
The macro comes from "src/mpl/confdb/ax_prefix_config_h.m4", and the
"src/mpl/confdb" directory is a bit special because it is an SVN
external.  Not only is it an SVN external, but it's a "relative"
external, which is a feature that was added in SVN 1.5 [1].
Do you have a "src/mpl/confdb" directory?
What version of SVN are you using?  Running "svn --version" should
tell you.  Please upgrade to 1.5 or later if you wish to use the SVN
version of MPICH2.
-Dave
[1] http://svnbook.red-bean.com/en/1.5/svn.advanced.externals.html
(see the paragraph "As of Subversion 1.5, though, a new format [...]")
On Jan 22, 2010, at 2:58 PM, Ryan Kroiss wrote:
> I'm having trouble building mpich2 with ROMIO enabled.  I need this
> so that I can work with IOFSL.  I've followed the instructions found
> at <https://trac.mcs.anl.gov/projects/iofsl/wiki/Building>.  I'm
> running automake version 1.11.1, autoconf version 2.63, and libtool
> version 2.2.6b.  I believe that I was able to run ./maint/
> updatefiles successfully (at least it completed without
> complaining).  After running this, I'm trying to run the following
> command:  ./configure --enable-romio --with-file-system=ufs+zoidfs.
> I get the following error though:
> /home/rrkroiss/libs/mpich2/src/mpl/configure: line 11066: syntax
> error near unexpected token `include/mplconfig.h,MPL'
> `AX_PREFIX_CONFIG_H(include/mplconfig.h,MPL)'
> configure: error: MPL configure failed
> Any help would be appreciated!
> Thanks,
> Ryan
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
