[mpich-discuss] Compilation of MPCH2-1.2.1 is failing onSunSolaris 10 (Sparc)
Arvind Petaru arvindpetaru at gmail.com
Thu Jan 21 15:34:41 CST 2010
same errors...
On Thu, Jan 21, 2010 at 4:34 PM, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
>  Does it give the same error or a different error?
> Rajeev
>  *From:* mpich-discuss-bounces at mcs.anl.gov [mailto:
> mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *Arvind Petaru
> *Sent:* Thursday, January 21, 2010 3:32 PM
> *To:* mpich-discuss at mcs.anl.gov
> *Subject:* Re: [mpich-discuss] Compilation of MPCH2-1.2.1 is failing
>   Forgot to mention earlier....I tried that too(--with-device=ch3:sock)
> and it fails........
> -Arvind
> On Thu, Jan 21, 2010 at 4:27 PM, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
>>  Can you try configuring with --with-device=ch3:sock (followed by make
>> and make install) and see if that works?
>> Rajeev
>> *Sent:* Thursday, January 21, 2010 2:19 PM
>> *Subject:* [mpich-discuss] Compilation of MPCH2-1.2.1 is failing on
>> Hi,
>>    I'm new to MPI programming.
>>    I installed MPICH2 on my Sun Solaris 10, SPARC version and tried to
>> configure & compile it on this machine.
>>    I was not able to compile it successfully and it throws lot of errors.
>> Not sure what could be the problem (or) if I am missing something.
>>    I'd appreciate if someone can help me in this regards.
>>    Attaching c.txt, m.txt, config.log, config.system and config.status
>> files for your reference.
>>     Let me know if you need any other info.
>> Cheers,
>> -Arvind
>> Cheers,
>> -Arvind
>> mpich-discuss mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Cheers,
> -Arvind
Cheers,
-Arvind
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100121/5f15b82c/attachment-0001.htm>
