[mpich-discuss] Compilation of MPCH2-1.2.1 is failing	onSunSolaris 10 (Sparc)
    Rajeev Thakur
    thakur at mcs.anl.gov
    Thu Jan 21 15:34:10 CST 2010
Does it give the same error or a different error?
Rajeev
  _____
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Arvind Petaru
Sent: Thursday, January 21, 2010 3:32 PM
Subject: Re: [mpich-discuss] Compilation of MPCH2-1.2.1 is failing onSunSolaris 10 (Sparc)
Forgot to mention earlier....I tried that too(--with-device=ch3:sock) and it fails........
-Arvind
On Thu, Jan 21, 2010 at 4:27 PM, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
Can you try configuring with --with-device=ch3:sock (followed by make and make install) and see if that works?
Rajeev
  _____
Sent: Thursday, January 21, 2010 2:19 PM
Subject: [mpich-discuss] Compilation of MPCH2-1.2.1 is failing on SunSolaris 10 (Sparc)
   I'm new to MPI programming.
   I installed MPICH2 on my Sun Solaris 10, SPARC version and tried to configure & compile it on this machine.
   I was not able to compile it successfully and it throws lot of errors. Not sure what could be the problem (or) if I am missing
something.
   I'd appreciate if someone can help me in this regards.
   Attaching c.txt, m.txt, config.log, config.system and config.status files for your reference.
    Let me know if you need any other info.
Cheers,
-Arvind
Cheers,
-Arvind
mpich-discuss mailing list
Cheers,
-Arvind
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100121/a43bfd86/attachment.htm>
