[mpich-discuss] Compilation of MPCH2-1.2.1 is failing on	SunSolaris 10 (Sparc)
    Arvind Petaru
    arvindpetaru at gmail.com
    Thu Jan 21 15:32:23 CST 2010
Forgot to mention earlier....I tried that too(--with-device=ch3:sock) and it
fails........
-Arvind
On Thu, Jan 21, 2010 at 4:27 PM, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
>  Can you try configuring with --with-device=ch3:sock (followed by make and
> make install) and see if that works?
> Rajeev
> *From:* mpich-discuss-bounces at mcs.anl.gov [mailto:
> mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *Arvind Petaru
> *Sent:* Thursday, January 21, 2010 2:19 PM
> *To:* mpich-discuss at mcs.anl.gov
> *Subject:* [mpich-discuss] Compilation of MPCH2-1.2.1 is failing on
> Hi,
>    I'm new to MPI programming.
>    I installed MPICH2 on my Sun Solaris 10, SPARC version and tried to
> configure & compile it on this machine.
>    I was not able to compile it successfully and it throws lot of errors.
> Not sure what could be the problem (or) if I am missing something.
>    I'd appreciate if someone can help me in this regards.
>    Attaching c.txt, m.txt, config.log, config.system and config.status
> files for your reference.
>     Let me know if you need any other info.
> Cheers,
> -Arvind
> Cheers,
> -Arvind
> mpich-discuss mailing list
Cheers,
-Arvind
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100121/f2defe73/attachment.htm>
