[mpich-discuss] mpiexec.hydra does not work in ClearCase vobs
chong tan chong_guan_tan at yahoo.com
Fri Jan 15 11:35:17 CST 2010
the directory is inside ClearCase vobs, knowns as 'view' in ClearCase.  It is only visible after
running the 'clearcase setview' command.
The way people got around probelm with Grid+Clearcase is to add a wrapper shell to check for the
env var CLEARCASE_ROOT, and run the clearcase setview command, like :
#!/bin/sh
   if [ X_$CLEARCASE_ROOT = X_ ] then
        # NOT Clearcase
   else
       cleartool setview -exec "whatever command commands " `basename $CLEARCASE_ROOT
   fi
make this the wrapper script to the grid.    (CLEARCASE_ROOT is of the form /view/<viewname>,
we only need the <viewname> part to set the view)
I think something like this will be need for mpiexec hydra.  Hopefully the info here is enough to get the
support into hydra.
tan
Sent: Thu, January 14, 2010 3:56:42 PM
Subject: Re: [mpich-discuss] mpiexec.hydra does not work in ClearCase vobs
Unfortunately, I don't know anything about ClearCase. Is the directory
you are launching mpiexec from available on all machines (I'm assuming
you are not explicitly setting -wdir in mpiexec)?
-- Pavan
On 01/14/2010 12:51 PM, Dave Goodell wrote:
> On Jan 14, 2010, at 12:42 PM, chong tan wrote:
>> if the wdir is in ClearCaseVob.  Getting this error:
>> [proxy at cappy] HYD_pmcd_pmi_proxy_launch_procs
>> (./pm/pmiserv/pmi_proxy_utils.c:658): unable to change wdir (No such
>> file or directory)
> Not sure about this here.  My limited understanding of ClearCase is that
> it provides its VCS capabilities in large part through a custom
> filesystem that is mounted on the machine.  So it's entirely possible
> that hydra and that filesystem are not interacting correctly.
> Unfortunately I don't believe that we have access to ClearCase here at
> ANL, so it will be very difficult for us to reproduce and debug the
> problem.  Pavan may have an idea of what's going on here, but otherwise
> we would welcome any patches or assistance that you can offer figuring
> out what's going on.
>> Another issue: it ask for my passwd on 'localhost' when I run
>> mpiexec.hydra locally.  This does not make much sense as I am already
>> logged in.
> It makes sense for various implementation reasons when you are using the
> default bootstrap server, "ssh".  If you only wish to run processes on
> the current node, you can use the "fork" bootstrap server:
> http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager#Bootstrap_Servers
> Basically pass "-bootstrap fork" to mpiexec or set the HYDRA_BOOTSTRAP
> environment variable to fork.
> -Dave
> mpich-discuss mailing list
Pavan Balaji
http://www.mcs.anl.gov/~balaji
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100115/73be30d6/attachment.htm>
