[mpich-discuss] mpiexec.hydra does not work in ClearCase vobs
    Pavan Balaji
    balaji at mcs.anl.gov
    Thu Jan 14 17:56:42 CST 2010
Unfortunately, I don't know anything about ClearCase. Is the directory
you are launching mpiexec from available on all machines (I'm assuming
you are not explicitly setting -wdir in mpiexec)?
 -- Pavan
On 01/14/2010 12:51 PM, Dave Goodell wrote:
> On Jan 14, 2010, at 12:42 PM, chong tan wrote:
>> if the wdir is in ClearCaseVob.  Getting this error:
>> [proxy at cappy] HYD_pmcd_pmi_proxy_launch_procs
>> (./pm/pmiserv/pmi_proxy_utils.c:658): unable to change wdir (No such
>> file or directory)
> Not sure about this here.  My limited understanding of ClearCase is that
> it provides its VCS capabilities in large part through a custom
> filesystem that is mounted on the machine.  So it's entirely possible
> that hydra and that filesystem are not interacting correctly.
> Unfortunately I don't believe that we have access to ClearCase here at
> ANL, so it will be very difficult for us to reproduce and debug the
> problem.  Pavan may have an idea of what's going on here, but otherwise
> we would welcome any patches or assistance that you can offer figuring
> out what's going on.
>> Another issue: it ask for my passwd on 'localhost' when I run
>> mpiexec.hydra locally.  This does not make much sense as I am already
>> logged in.
> It makes sense for various implementation reasons when you are using the
> default bootstrap server, "ssh".  If you only wish to run processes on
> the current node, you can use the "fork" bootstrap server:
> http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager#Bootstrap_Servers
> Basically pass "-bootstrap fork" to mpiexec or set the HYDRA_BOOTSTRAP
> environment variable to fork.
> -Dave
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Pavan Balaji
http://www.mcs.anl.gov/~balaji
