[mpich-discuss] Trouble compiling MPICH2 (mpich2-1.2.1-win-x86-64) with mingw-w64
jayesh at mcs.anl.gov jayesh at mcs.anl.gov
Thu Feb 25 09:14:33 CST 2010
 Sorry... I didn't get any window to work on this issue. I will keep you posted (In a day or two I should be able to get back to you).
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Cc: mpich-discuss at mcs.anl.gov
Sent: Thursday, February 25, 2010 4:54:32 AM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] Trouble compiling MPICH2 (mpich2-1.2.1-win-x86-64)  with mingw-w64
Hi!
Any luck with the 64 bit mingw + mpich2 on windows? I'm still hitting into the same linker issues, but it runs OK in 32 bit.
C:\C_code>"C:\Documents and Settings\Administrator\Desktop\mingw-w64-bin-x86_64-20100131\mingw64\bin\gcc.exe" -I "C:\Program Files\MPICH2\include" -L "C:\Program Files\MPICH2\lib" prog.c -lmpi
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0xd7): undefined reference to `MPI_Init'
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0xe1): undefined reference to `MPI_Barrier'
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0xe6): undefined reference to `MPI_Wtime'
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0x108): undefined reference to `MPI_Comm_rank'
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0x119): undefined reference to `MPI_Comm_size'
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0x143): undefined reference to `MPI_Finalize'
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0x242): undefined reference to `MPI_Finalize'
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0x274): undefined reference to `MPI_Finalize'
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0x39e): undefined reference to `MPI_Bcast'
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0x424): undefined reference to `MPI_Reduce'
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0x429): undefined reference to `MPI_Wtime'
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0x48e): undefined reference to `MPI_Finalize'
collect2: ld returned 1 exit status
Thanks!
Sanchay
On Tue, Feb 23, 2010 at 10:52 PM, Jayesh Krishna < jayesh at mcs.anl.gov > wrote:
Thanks. I will try the one from sourceforge (ver = 20100223) and let you know how it goes.
(PS: From the error messages it looks like the symbol naming convention of mingw64 is different from mingw32)
Jayesh
To: jayesh at mcs.anl.gov
Sent: Tuesday, February 23, 2010 2:28:43 PM GMT -06:00 US/Canada Central
In case this helps:
20100131\mingw64\bin\gcc.exe" -v
Using built-in specs.
COLLECT_GCC=C:\Documents and Settings\Administrator\Desktop\mingw-w64-bin-x86_64
COLLECT_LTO_WRAPPER=c:/documents and settings/administrator/desktop/mingw-w64-bi
n-x86_64-20100131/mingw64/bin/../libexec/gcc/x86_64-w64-mingw32/4.5.0/lto-wrappe
r.exe
Target: x86_64-w64-mingw32
Configured with: /home/drangon/work_dgn/mingw-w64-dgn/source/gcc/configure --hos
t=x86_64-w64-mingw32 --target=x86_64-w64-mingw32 --disable-nls --enable-language
s=c,c++ --with-gmp=/home/drangon/work_dgn/mingw-w64-dgn/build/for_target --enabl
e-twoprocess --disable-libstdcxx-pch --prefix=/home/drangon/work_dgn/mingw-w64-d
gn/target --with-sysroot=/home/drangon/work_dgn/mingw-w64-dgn/target
Thread model: win32
gcc version 4.5.0 20100131 (experimental) (GCC)
Thanks
On Tue, Feb 23, 2010 at 9:23 PM, Sanchay Harneja < sanchay.h at gmail.com > wrote:
I tried -m64 at all possible places to compiler args but to no avail.
I downloaded the compiler from here: http://www.drangon.org/mingw/
File I downloaded: mingw-w64-bin-x86_64-20100131.7z
My OS: Windows XP 64 bit
Meanwhile I'll keep trying!
Thanks
Sanchay
On Tue, Feb 23, 2010 at 8:49 PM, < jayesh at mcs.anl.gov > wrote:
Can you try adding "-m64" to the compiler flags and see if it works ? If not, please let me know how you installed mingw64 (I have had bad experiences in the past with compiling/installing the compiler) - installable? compiled on cygwin ? src version ? etc - so that I can provide you further help.
Jayesh
To: "Jayesh Krishna" < jayesh at mcs.anl.gov >
Sent: Tuesday, February 23, 2010 1:13:43 PM GMT -06:00 US/Canada Central
Hi Jayesh,
I now have,
#include <windows.h>
#include <mpi.h>
But I'm getting the following errors now -
Thanks for helping!
Sanchay
On Mon, Feb 22, 2010 at 4:20 PM, Jayesh Krishna < jayesh at mcs.anl.gov > wrote:
Try including "windows.h" in your MPI program (before including mpi.h) and let us know if it works for you.
Jayesh
Sent: Sunday, February 21, 2010 5:16:16 PM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] Trouble compiling MPICH2 (mpich2-1.2.1-win-x86-64) with mingw-w64
I'm trying to compile a C program on Windows XP 64 bit with the mingw-w64 compiler. But I'm getting errors as follows.
I downloaded the MPICH2 lib from: http://www.mcs.anl.gov/research/projects/mpich2/ .
And downloaded the mingw compiler from: http://www.drangon.org/mingw/ (mingw-w64-bin-x86_64-20100131.7z)
Note that the program compiles successfully with the 32 bit mingw compiler and the 32 bit MPICH2 (mpich2-1.2.1-win-ia32.msi).
In file included from prog.c:16:0:
C:\Program Files\MPICH2\include/mpi.h:360:17: error: expected '=', ',', ';', 'as
m' or '__attribute__' before 'MPI_Aint'
C:\Program Files\MPICH2\include/mpi.h:550:66: error: expected declaration specif
iers or '...' before 'MPI_Aint'
C:\Program Files\MPICH2\include/mpi.h:608:32: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:610:35: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:611:33: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:612:24: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:614:35: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:620:31: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:621:31: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:736:52: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:738:45: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:740:45: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:743:28: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:788:64: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:825:29: error: expected ')' before 'MPI_In
fo'
C:\Program Files\MPICH2\include/mpi.h:834:29: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:844:66: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:845:23: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:846:55: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:852:43: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:854:39: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:857:43: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:857:53: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:858:41: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:862:39: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:862:51: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:863:44: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:863:56: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:864:41: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:864:51: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:930:33: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:932:36: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:933:34: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:934:25: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:935:36: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:937:32: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:938:32: error: expected declaration specif
C:\Program Files\MPICH2\include/mpi.h:1043:53: error: expected declaration speci
fiers or '...' before 'MPI_Aint'
C:\Program Files\MPICH2\include/mpi.h:1045:46: error: expected declaration speci
C:\Program Files\MPICH2\include/mpi.h:1047:46: error: expected declaration speci
C:\Program Files\MPICH2\include/mpi.h:1050:29: error: expected declaration speci
C:\Program Files\MPICH2\include/mpi.h:1095:65: error: expected declaration speci
C:\Program Files\MPICH2\include/mpi.h:1120:30: error: expected ')' before 'MPI_I
nfo'
C:\Program Files\MPICH2\include/mpi.h:1129:30: error: expected declaration speci
C:\Program Files\MPICH2\include/mpi.h:1139:67: error: expected declaration speci
C:\Program Files\MPICH2\include/mpi.h:1140:23: error: expected declaration speci
C:\Program Files\MPICH2\include/mpi.h:1141:56: error: expected declaration speci
C:\Program Files\MPICH2\include/mpi.h:1147:44: error: expected declaration speci
C:\Program Files\MPICH2\include/mpi.h:1149:40: error: expected declaration speci
C:\Program Files\MPICH2\include/mpi.h:1152:44: error: expected declaration speci
C:\Program Files\MPICH2\include/mpi.h:1152:54: error: expected declaration speci
C:\Program Files\MPICH2\include/mpi.h:1153:42: error: expected declaration speci
C:\Program Files\MPICH2\include/mpi.h:1157:40: error: expected declaration speci
C:\Program Files\MPICH2\include/mpi.h:1157:52: error: expected declaration speci
C:\Program Files\MPICH2\include/mpi.h:1158:45: error: expected declaration speci
C:\Program Files\MPICH2\include/mpi.h:1158:57: error: expected declaration speci
C:\Program Files\MPICH2\include/mpi.h:1159:42: error: expected declaration speci
C:\Program Files\MPICH2\include/mpi.h:1159:52: error: expected declaration speci
In file included from C:\Program Files\MPICH2\include/mpi.h:1186:0,
from prog.c:16:
C:\Program Files\MPICH2\include/mpio.h:206:54: error: expected declaration speci
C:\Program Files\MPICH2\include/mpio.h:391:55: error: expected declaration speci
prog.c: In function 'main':
prog.c:69:9: warning: incompatible implicit declaration of bu
ilt-in function 'exit'
prog.c:90:9: warning: incompatible implicit declaration of bu
prog.c:97:23: warning: incompatible implicit declaration of b
uilt-in function 'malloc'
prog.c:104:9: warning: incompatible implicit declaration of b
uilt-in function 'exit'
C:\C_code>
Thanks!
Sanchay
mpich-discuss mailing list
