[mpich-discuss] ROMIO with SGI MPI MPI_TYPE_MAX
burlen burlen.loring at gmail.com
Fri Feb 26 15:45:46 CST 2010
Hi All,
I have been running into some issues when using SGI MPI and collective
IO. My program always crashes with the error
    MPI has run out of internal datatype entries.
It's quite quick with the default 8192, upping the value does prolong
the life of the program but it will still crash after about 300 ish type
commit/read/type free operations. Which to me doesn't seem like a very
large number for an HPC app.
Also I have found a way to reproduce this after only two explicit type
commit in my application. There are some point to point communication as
well but none of them commit any types. And we're talking about only a
handful of MPI calls issued. This reproduction depends on how many
process per node are scheduled , eg 1 per core. I have been careful to
see that I'm not leaking types, so my conclusion is that SGI MPI is
leaking types internally.
I was surprised to see a blurb about just this issue in ROMIO user manual.
Can anyone out there shed some light on this?
Thanks
Burlen
• When using ROMIO with SGI MPI, you may sometimes get an error message
from SGI
MPI: “MPI has run out of internal datatype entries. Please set the
environment variable
MPI TYPE MAX for additional space.” If you get this error message, add
the following line to
your .cshrc file:
setenv MPI TYPE MAX 65536
Use a larger number if you still get the error message.
