[mpich-discuss] Can I run MPI program without mpirun/mpiexec?
John Xu johnzxu at gmail.com
Tue Feb 23 16:25:58 CST 2010
I am trying to start up mpi process in a processor simulator
environment. So I have the same problem
as formerly posted in
 https://lists.mcs.anl.gov/mailman/htdig/mpich-discuss/2009-November/006008.html
Jayesh,
You indicated that there is a way similar to the windows debugging by
starting processes at manually.
But it requires two command prompts.
Does it work for a linux environment running SMP with say 2 cores?
Since I only have one dummy term emulated from the simulator, I can
not get two command prompts.
Can I setup the environment as in your document and start two
processes in the background?
thanks,
john
 Yes, you can run an MPI program without mpiexec/mpirun. Let us know
if you have any problems.
Jayesh
----- Original Message -----
Sent: Friday, November 20, 2009 2:58:30 PM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] Can I run MPI program without mpirun/mpiexec?
Hi everyone:
I want to run mpi program like a normal binary without mpirun/mpiexec
command, like this: ./mpi_hello . Is this possible?
This is possible only that I can compile mpi program and put all the
runtime information into a stand alone binary. I don't know if it is
possible.
Thank you very much!
Junli Gu--谷俊丽
Coordinate Science Lab
University of Illinois at Urbana-Champaign
