[mpich-discuss] Trouble compiling MPICH2 (mpich2-1.2.1-win-x86-64) with mingw-w64
Sanchay Harneja
sanchay.h at gmail.com
Thu Feb 25 04:54:32 CST 2010
Hi!
Any luck with the 64 bit mingw + mpich2 on windows? I'm still hitting into
the same linker issues, but it runs OK in 32 bit.
C:\C_code>"C:\Documents and
Settings\Administrator\Desktop\mingw-w64-bin-x86_64-20100131\mingw64\bin\gcc.exe"
-I "C:\Program Files\MPICH2\include" -L "C:\Program Files\MPICH2\lib" prog.c
-lmpi
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0xd7): undefined
reference to `MPI_Init'
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0xe1): undefined
reference to `MPI_Barrier'
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0xe6): undefined
reference to `MPI_Wtime'
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0x108):
undefined reference to `MPI_Comm_rank'
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0x119):
undefined reference to `MPI_Comm_size'
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0x143):
undefined reference to `MPI_Finalize'
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0x242):
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0x274):
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0x39e):
undefined reference to `MPI_Bcast'
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0x424):
undefined reference to `MPI_Reduce'
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0x429):
undefined reference to `MPI_Wtime'
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccG2CWiZ.o:prog.c:(.text+0x48e):
collect2: ld returned 1 exit status
Thanks!
Sanchay
On Tue, Feb 23, 2010 at 10:52 PM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
> Thanks. I will try the one from sourceforge (ver = 20100223) and let you
> know how it goes.
> (PS: From the error messages it looks like the symbol naming convention of
> mingw64 is different from mingw32)
> Regards,
> Jayesh
> From: "Sanchay Harneja" <sanchay.h at gmail.com>
> To: jayesh at mcs.anl.gov
> Cc: mpich-discuss at mcs.anl.gov
> Sent: Tuesday, February 23, 2010 2:28:43 PM GMT -06:00 US/Canada Central
> Subject: Re: [mpich-discuss] Trouble compiling MPICH2
> In case this helps:
> 20100131\mingw64\bin\gcc.exe" -v
> Using built-in specs.
> COLLECT_GCC=C:\Documents and
> COLLECT_LTO_WRAPPER=c:/documents and
> settings/administrator/desktop/mingw-w64-bi
> n-x86_64-20100131/mingw64/bin/../libexec/gcc/x86_64-w64-mingw32/4.5.0/lto-wrappe
> r.exe
> Target: x86_64-w64-mingw32
> Configured with: /home/drangon/work_dgn/mingw-w64-dgn/source/gcc/configure
> --hos
> t=x86_64-w64-mingw32 --target=x86_64-w64-mingw32 --disable-nls
> --enable-language
> s=c,c++ --with-gmp=/home/drangon/work_dgn/mingw-w64-dgn/build/for_target
> --enabl
> e-twoprocess --disable-libstdcxx-pch
> --prefix=/home/drangon/work_dgn/mingw-w64-d
> gn/target --with-sysroot=/home/drangon/work_dgn/mingw-w64-dgn/target
> Thread model: win32
> gcc version 4.5.0 20100131 (experimental) (GCC)
> Thanks
> On Tue, Feb 23, 2010 at 9:23 PM, Sanchay Harneja < sanchay.h at gmail.com >
> wrote:
> Hi,
> I tried -m64 at all possible places to compiler args but to no avail.
> I downloaded the compiler from here: http://www.drangon.org/mingw/
> File I downloaded: mingw-w64-bin-x86_64-20100131.7z
> My OS: Windows XP 64 bit
> Meanwhile I'll keep trying!
> Thanks
> Sanchay
> On Tue, Feb 23, 2010 at 8:49 PM, < jayesh at mcs.anl.gov > wrote:
> Hi,
> Can you try adding "-m64" to the compiler flags and see if it works ? If
> not, please let me know how you installed mingw64 (I have had bad
> experiences in the past with compiling/installing the compiler) -
> installable? compiled on cygwin ? src version ? etc - so that I can provide
> you further help.
> Regards,
> Jayesh
> From: "Sanchay Harneja" < sanchay.h at gmail.com >
> To: "Jayesh Krishna" < jayesh at mcs.anl.gov >
> Sent: Tuesday, February 23, 2010 1:13:43 PM GMT -06:00 US/Canada Central
> Hi Jayesh,
> I now have,
> #include <windows.h>
> #include <mpi.h>
> But I'm getting the following errors now -
> 20100131\mingw64\bin\gcc.exe" -I "C:\Program Files\MPICH2\include" -L
> "C:\Progra
> m Files\MPICH2\lib" prog.c -lmpi
> xd7): undefined reference to `MPI_Init'
> xe1): undefined reference to `MPI_Barrier'
> xe6): undefined reference to `MPI_Wtime'
> x108): undefined reference to `MPI_Comm_rank'
> x119): undefined reference to `MPI_Comm_size'
> x143): undefined reference to `MPI_Finalize'
> x242): undefined reference to `MPI_Finalize'
> x274): undefined reference to `MPI_Finalize'
> x39e): undefined reference to `MPI_Bcast'
> x424): undefined reference to `MPI_Reduce'
> x429): undefined reference to `MPI_Wtime'
> x48e): undefined reference to `MPI_Finalize'
> Thanks for helping!
> Sanchay
> On Mon, Feb 22, 2010 at 4:20 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
> wrote:
> Hi,
> Try including "windows.h" in your MPI program (before including mpi.h) and
> let us know if it works for you.
> Regards,
> Jayesh
> To: mpich-discuss at mcs.anl.gov
> Sent: Sunday, February 21, 2010 5:16:16 PM GMT -06:00 US/Canada Central
> Subject: [mpich-discuss] Trouble compiling MPICH2 (mpich2-1.2.1-win-x86-64)
> with mingw-w64
> Hi,
> I'm trying to compile a C program on Windows XP 64 bit with the mingw-w64
> compiler. But I'm getting errors as follows.
> I downloaded the MPICH2 lib from:
> http://www.mcs.anl.gov/research/projects/mpich2/ .
> And downloaded the mingw compiler from: http://www.drangon.org/mingw/(mingw-w64-bin-x86_64-20100131.7z)
> Note that the program compiles successfully with the 32 bit mingw compiler
> and the 32 bit MPICH2 (mpich2-1.2.1-win-ia32.msi).
> "C:\Progra
> In file included from prog.c:16:0:
> C:\Program Files\MPICH2\include/mpi.h:360:17: error: expected '=', ',',
> ';', 'as
> m' or '__attribute__' before 'MPI_Aint'
> C:\Program Files\MPICH2\include/mpi.h:550:66: error: expected declaration
> specif
> iers or '...' before 'MPI_Aint'
> C:\Program Files\MPICH2\include/mpi.h:608:32: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:610:35: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:611:33: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:612:24: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:614:35: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:620:31: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:621:31: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:736:52: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:738:45: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:740:45: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:743:28: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:788:64: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:825:29: error: expected ')' before
> 'MPI_In
> fo'
> C:\Program Files\MPICH2\include/mpi.h:834:29: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:844:66: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:845:23: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:846:55: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:852:43: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:854:39: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:857:43: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:857:53: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:858:41: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:862:39: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:862:51: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:863:44: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:863:56: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:864:41: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:864:51: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:930:33: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:932:36: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:933:34: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:934:25: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:935:36: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:937:32: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:938:32: error: expected declaration
> specif
> C:\Program Files\MPICH2\include/mpi.h:1043:53: error: expected declaration
> speci
> fiers or '...' before 'MPI_Aint'
> C:\Program Files\MPICH2\include/mpi.h:1045:46: error: expected declaration
> speci
> C:\Program Files\MPICH2\include/mpi.h:1047:46: error: expected declaration
> speci
> C:\Program Files\MPICH2\include/mpi.h:1050:29: error: expected declaration
> speci
> C:\Program Files\MPICH2\include/mpi.h:1095:65: error: expected declaration
> speci
> C:\Program Files\MPICH2\include/mpi.h:1120:30: error: expected ')' before
> 'MPI_I
> nfo'
> C:\Program Files\MPICH2\include/mpi.h:1129:30: error: expected declaration
> speci
> C:\Program Files\MPICH2\include/mpi.h:1139:67: error: expected declaration
> speci
> C:\Program Files\MPICH2\include/mpi.h:1140:23: error: expected declaration
> speci
> C:\Program Files\MPICH2\include/mpi.h:1141:56: error: expected declaration
> speci
> C:\Program Files\MPICH2\include/mpi.h:1147:44: error: expected declaration
> speci
> C:\Program Files\MPICH2\include/mpi.h:1149:40: error: expected declaration
> speci
> C:\Program Files\MPICH2\include/mpi.h:1152:44: error: expected declaration
> speci
> C:\Program Files\MPICH2\include/mpi.h:1152:54: error: expected declaration
> speci
> C:\Program Files\MPICH2\include/mpi.h:1153:42: error: expected declaration
> speci
> C:\Program Files\MPICH2\include/mpi.h:1157:40: error: expected declaration
> speci
> C:\Program Files\MPICH2\include/mpi.h:1157:52: error: expected declaration
> speci
> C:\Program Files\MPICH2\include/mpi.h:1158:45: error: expected declaration
> speci
> C:\Program Files\MPICH2\include/mpi.h:1158:57: error: expected declaration
> speci
> C:\Program Files\MPICH2\include/mpi.h:1159:42: error: expected declaration
> speci
> C:\Program Files\MPICH2\include/mpi.h:1159:52: error: expected declaration
> speci
> In file included from C:\Program Files\MPICH2\include/mpi.h:1186:0,
> from prog.c:16:
> C:\Program Files\MPICH2\include/mpio.h:206:54: error: expected declaration
> speci
> C:\Program Files\MPICH2\include/mpio.h:391:55: error: expected declaration
> speci
> prog.c: In function 'main':
> prog.c:69:9: warning: incompatible implicit declaration of bu
> ilt-in function 'exit'
> prog.c:90:9: warning: incompatible implicit declaration of bu
> prog.c:97:23: warning: incompatible implicit declaration of b
> uilt-in function 'malloc'
> prog.c:104:9: warning: incompatible implicit declaration of b
> uilt-in function 'exit'
> C:\C_code>
> Thanks!
> Sanchay
> mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100225/d156b95d/attachment-0001.htm>
