[mpich-discuss] A Windows 7 implementation question
Jayesh Krishna
jayesh at mcs.anl.gov
Tue Feb 23 11:14:42 CST 2010
Also, take a close look at the following Local Security policies,
1) Allow log on locally
2) Log on as a batch job
Jayesh
----- Original Message -----
Sent: Tuesday, February 23, 2010 10:40:31 AM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] A Windows 7 implementation question
Are you able to run MPI programs as the "background user", locally on the machine, after logging in as the "background user" (Login as the background user, Register the background user using "mpiexec -register" , Try running programs as the background user "mpiexec -n 2 hostname" )?
Jayesh
Sent: Tuesday, February 23, 2010 9:58:45 AM GMT -06:00 US/Canada Central
No expert, we're walking the minefield for everyone else, but you're suggestion is one that sounds worth following up on. Thanks, as long as I have ideas, then there's hope for a practical solution.
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Biddiscombe, John A.
Sent: Tuesday, February 23, 2010 3:02 AM
I have no expertise in the matter, but I’d bet that there is a ‘group policy’ setting/object somewhere that will allow you to enable background tasks/processes from other users via remote connections. Do you have some expert administrator for windows stuff that might know? (I tried googling, but there were too many unrelated hits).
JB
4 - Am I overlooking some other obvious solution that would be easier and solve all these problems beyond having to buy a whole new set of dedicated systems to run as a full time test cluster (right now I'll never get funding for that but I realize that is the solution that SHOULD be done, but I don't have anyone to bankroll it).
mpich-discuss mailing list
