[mpich-discuss] ./maint/updatefiles and configure problems
Pavan Balaji balaji at mcs.anl.gov
Sun Feb 14 22:59:14 CST 2010
Looks like you don't have automake-1.11.
 -- Pavan
On 02/14/2010 10:24 PM, Jeff Hammond wrote:
> I did the usual "svn update" and ./maint/updatefiles  on the mpich2
> trunk but there were problems in the second stage as well as the
> subsequent configure step.
> I'm not dependent on this code, so there is no urgency in fixing what
> I perceive to be a problem.
> Thanks,
> Jeff
> step 1
> jeff at megatron:/software/mpich/mpich2-trunk> svn update
> step 2
> jeff at megatron:/software/mpich/mpich2-trunk> ./maint/updatefiles
> You have autoconf version 2.63 or greater.
> Checking that libtool version is acceptable...
> running autoreconf in src/pm/hydra
> autoreconf: Entering directory `.'
> autoreconf: configure.in: not using Gettext
> autoreconf: running: aclocal --force -I mpl/confdb
> configure.in:181: warning: macro `AM_SUBST_NOTMAKE' not found in library
> configure.in:182: warning: macro `AM_SUBST_NOTMAKE' not found in library
> configure.in:183: warning: macro `AM_SUBST_NOTMAKE' not found in library
> configure.in:195: warning: macro `AM_SUBST_NOTMAKE' not found in library
> configure.in:231: warning: macro `AM_SUBST_NOTMAKE' not found in library
> configure.in:237: warning: macro `AM_SUBST_NOTMAKE' not found in library
> configure.in:238: warning: macro `AM_SUBST_NOTMAKE' not found in library
> configure.in:239: warning: macro `AM_SUBST_NOTMAKE' not found in library
> autoreconf: configure.in: tracing
> autoreconf: running: libtoolize --copy --force
> libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, `mpl/confdb'.
> libtoolize: copying file `mpl/confdb/ltmain.sh'
> libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `mpl/confdb'.
> libtoolize: copying file `mpl/confdb/libtool.m4'
> libtoolize: copying file `mpl/confdb/ltoptions.m4'
> libtoolize: copying file `mpl/confdb/ltsugar.m4'
> libtoolize: copying file `mpl/confdb/ltversion.m4'
> libtoolize: copying file `mpl/confdb/lt~obsolete.m4'
> autoreconf: running: /usr/bin/autoconf --force
> configure.in:183: error: possibly undefined macro: AM_SUBST_NOTMAKE
>       If this token and others are legitimate, please use m4_pattern_allow.
>       See the Autoconf documentation.
> autoreconf: /usr/bin/autoconf failed with exit status: 1
> step 3
> jeff at megatron:/software/mpich/mpich2-trunk> ./configure CC=gcc CXX=g++
> F77=gfortran FC=gfortran
> --prefix=/software/mpich/gnu-build-mpich2-trunk
> --with-thread-package=pthreads --enable-threads=default --enable-f77
> --enable-f90 --enable-cxx --enable-romio --enable-smpcoll --enable-mpe
> --with-pm=hydra
> checking boot-strap server... ssh,rsh,fork,slurm,persist
> /software/mpich/mpich2-trunk/src/pm/hydra/configure: line 12966:
> syntax error near unexpected token `hydra_bss_init_decl'
> `AM_SUBST_NOTMAKE(hydra_bss_init_decl)'
Pavan Balaji
http://www.mcs.anl.gov/~balaji
