[mpich-discuss] ./maint/updatefiles and configure problems
Jeff Hammond jhammond at mcs.anl.gov
Sun Feb 14 22:24:09 CST 2010
I did the usual "svn update" and ./maint/updatefiles  on the mpich2
trunk but there were problems in the second stage as well as the
subsequent configure step.
I'm not dependent on this code, so there is no urgency in fixing what
I perceive to be a problem.
Jeff
step 1
jeff at megatron:/software/mpich/mpich2-trunk> svn update
step 2
jeff at megatron:/software/mpich/mpich2-trunk> ./maint/updatefiles
You have autoconf version 2.63 or greater.
Checking that libtool version is acceptable...
running autoreconf in src/pm/hydra
autoreconf: Entering directory `.'
autoreconf: configure.in: not using Gettext
autoreconf: running: aclocal --force -I mpl/confdb
configure.in:181: warning: macro `AM_SUBST_NOTMAKE' not found in library
configure.in:182: warning: macro `AM_SUBST_NOTMAKE' not found in library
configure.in:183: warning: macro `AM_SUBST_NOTMAKE' not found in library
configure.in:195: warning: macro `AM_SUBST_NOTMAKE' not found in library
configure.in:231: warning: macro `AM_SUBST_NOTMAKE' not found in library
configure.in:237: warning: macro `AM_SUBST_NOTMAKE' not found in library
configure.in:238: warning: macro `AM_SUBST_NOTMAKE' not found in library
configure.in:239: warning: macro `AM_SUBST_NOTMAKE' not found in library
autoreconf: configure.in: tracing
autoreconf: running: libtoolize --copy --force
libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, `mpl/confdb'.
libtoolize: copying file `mpl/confdb/ltmain.sh'
libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `mpl/confdb'.
libtoolize: copying file `mpl/confdb/libtool.m4'
libtoolize: copying file `mpl/confdb/ltoptions.m4'
libtoolize: copying file `mpl/confdb/ltsugar.m4'
libtoolize: copying file `mpl/confdb/ltversion.m4'
libtoolize: copying file `mpl/confdb/lt~obsolete.m4'
autoreconf: running: /usr/bin/autoconf --force
configure.in:183: error: possibly undefined macro: AM_SUBST_NOTMAKE
      If this token and others are legitimate, please use m4_pattern_allow.
      See the Autoconf documentation.
autoreconf: /usr/bin/autoconf failed with exit status: 1
step 3
jeff at megatron:/software/mpich/mpich2-trunk> ./configure CC=gcc CXX=g++
F77=gfortran FC=gfortran
--prefix=/software/mpich/gnu-build-mpich2-trunk
--with-thread-package=pthreads --enable-threads=default --enable-f77
--enable-f90 --enable-cxx --enable-romio --enable-smpcoll --enable-mpe
--with-pm=hydra
checking boot-strap server... ssh,rsh,fork,slurm,persist
/software/mpich/mpich2-trunk/src/pm/hydra/configure: line 12966:
syntax error near unexpected token `hydra_bss_init_decl'
`AM_SUBST_NOTMAKE(hydra_bss_init_decl)'
Jeff Hammond
Argonne Leadership Computing Facility
jhammond at mcs.anl.gov / (630) 252-5381
http://www.linkedin.com/in/jeffhammond
