[mpich-discuss] ./maint/updatefiles and configure problems
Jeff Hammond jhammond at mcs.anl.gov
Mon Feb 15 07:27:52 CST 2010
Can ./maint/updatefiles be instrumented to check for that
compatibility as well (i.e. in addition to autoconf 2.63)?  That would
help us noobs running a GNU toolchain that's more than three months
old :)
Jeff
On Sun, Feb 14, 2010 at 10:59 PM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
> Looks like you don't have automake-1.11.
>  -- Pavan
> On 02/14/2010 10:24 PM, Jeff Hammond wrote:
>> I did the usual "svn update" and ./maint/updatefiles  on the mpich2
>> trunk but there were problems in the second stage as well as the
>> subsequent configure step.
>> I'm not dependent on this code, so there is no urgency in fixing what
>> I perceive to be a problem.
>> Thanks,
>> Jeff
>> step 1
>> jeff at megatron:/software/mpich/mpich2-trunk> svn update
>> step 2
>> jeff at megatron:/software/mpich/mpich2-trunk> ./maint/updatefiles
>> You have autoconf version 2.63 or greater.
>> Checking that libtool version is acceptable...
>> running autoreconf in src/pm/hydra
>> autoreconf: Entering directory `.'
>> autoreconf: configure.in: not using Gettext
>> autoreconf: running: aclocal --force -I mpl/confdb
>> configure.in:181: warning: macro `AM_SUBST_NOTMAKE' not found in library
>> configure.in:182: warning: macro `AM_SUBST_NOTMAKE' not found in library
>> configure.in:183: warning: macro `AM_SUBST_NOTMAKE' not found in library
>> configure.in:195: warning: macro `AM_SUBST_NOTMAKE' not found in library
>> configure.in:231: warning: macro `AM_SUBST_NOTMAKE' not found in library
>> configure.in:237: warning: macro `AM_SUBST_NOTMAKE' not found in library
>> configure.in:238: warning: macro `AM_SUBST_NOTMAKE' not found in library
>> configure.in:239: warning: macro `AM_SUBST_NOTMAKE' not found in library
>> autoreconf: configure.in: tracing
>> autoreconf: running: libtoolize --copy --force
>> libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, `mpl/confdb'.
>> libtoolize: copying file `mpl/confdb/ltmain.sh'
>> libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `mpl/confdb'.
>> libtoolize: copying file `mpl/confdb/libtool.m4'
>> libtoolize: copying file `mpl/confdb/ltoptions.m4'
>> libtoolize: copying file `mpl/confdb/ltsugar.m4'
>> libtoolize: copying file `mpl/confdb/ltversion.m4'
>> libtoolize: copying file `mpl/confdb/lt~obsolete.m4'
>> autoreconf: running: /usr/bin/autoconf --force
>> configure.in:183: error: possibly undefined macro: AM_SUBST_NOTMAKE
>>       If this token and others are legitimate, please use m4_pattern_allow.
>>       See the Autoconf documentation.
>> autoreconf: /usr/bin/autoconf failed with exit status: 1
>> step 3
>> jeff at megatron:/software/mpich/mpich2-trunk> ./configure CC=gcc CXX=g++
>> F77=gfortran FC=gfortran
>> --prefix=/software/mpich/gnu-build-mpich2-trunk
>> --with-thread-package=pthreads --enable-threads=default --enable-f77
>> --enable-f90 --enable-cxx --enable-romio --enable-smpcoll --enable-mpe
>> --with-pm=hydra
>> checking boot-strap server... ssh,rsh,fork,slurm,persist
>> /software/mpich/mpich2-trunk/src/pm/hydra/configure: line 12966:
>> syntax error near unexpected token `hydra_bss_init_decl'
>> `AM_SUBST_NOTMAKE(hydra_bss_init_decl)'
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Jeff Hammond
Argonne Leadership Computing Facility
jhammond at mcs.anl.gov / (630) 252-5381
http://www.linkedin.com/in/jeffhammond
