[mpich-discuss] Make error: No module named distutils.core
David Ladd
d.ladd at auckland.ac.nz
Sun Feb 14 17:48:56 CST 2010
Thanks, Rajeev- that did the trick!
Cheers,
David
Rajeev Thakur wrote:
> Can you try configuring with --disable-totalview.
> Rajeev
>> -----Original Message-----
>> From: mpich-discuss-bounces at mcs.anl.gov
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of David Ladd
>> Sent: Sunday, February 14, 2010 4:44 PM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: [mpich-discuss] Make error: No module named distutils.core
>> Hi all,
>> I seem to be having some issues setting up mpich2 on our
>> cluster. It is apparently unable to find python's distutils
>> while making src/slog2sdk:
>> Traceback (most recent call last):
>> File "./mtv_setup.py", line 7, in ?
>> from distutils.core import setup, Extension
>> ImportError: No module named distutils.core
>> which is located: /usr/lib/python2.4/distutils/core.py
>> Any help or suggestions would be greatly appreciated- please
>> see m.txt and c.txt attached.
>> Thanks,
>> David
> mpich-discuss mailing list
