[mpich-discuss] mpich2 configure error with intel 11 compiler
Anthony Chan
chan at mcs.anl.gov
Wed Feb 10 23:46:20 CST 2010
your config.log shows that your ifort isn't working correctly.
configure:7724: ifort -c conftest.f >&5
/usr/cluster/intel-fortran/bin/intel64/fortcom: error while loading shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory
ifort: error #10273: Fatal error in /usr/cluster/intel-fortran/bin/intel64/fortcom, terminated by 0x7f
Can you use ifort to compile a simple helloworld fortran program.
Also, CXX should be set to g++ not gcc.
A.Chan
----- "saar raas" <raas_saar at yahoo.com> wrote:
> Hello,
> I have installed the Intel fortran compiler and would like to link it
> with mpich2. I am running configure with device:ssm as it is a dual
> socket with quad-core xeons. I am using the following command
> ./configure -with-device=ch3:ssm -prefix=/usr/cluster/mpich2-1.2.1
> CC=gcc CXX=gcc F77=ifort F90=ifort
> I am getting an error saying "....configure: error: could not compile
> fortran test program"
> I have attached the config.log file.
> Appreciate your time and help.
> Thanks
> Raasik
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
