[mpich-discuss] mpich2 configure error with intel 11 compiler
saar raas raas_saar at yahoo.com
Thu Feb 11 00:16:36 CST 2010
I did not notice that message. Thanks for pointing it out, I will work on rectifying that.
Thanks again,
Raasik
--- On Thu, 2/11/10, Anthony Chan <chan at mcs.anl.gov> wrote:
Subject: Re: [mpich-discuss] mpich2 configure error with intel 11 compiler
Date: Thursday, February 11, 2010, 12:46 AM
your config.log shows that your ifort isn't working correctly.
configure:7724: ifort -c  conftest.f >&5
/usr/cluster/intel-fortran/bin/intel64/fortcom: error while loading shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory
ifort: error #10273: Fatal error in /usr/cluster/intel-fortran/bin/intel64/fortcom, terminated by 0x7f
Can you use ifort to compile a simple helloworld fortran program.
Also, CXX should be set to g++ not gcc.
A.Chan
----- "saar raas" <raas_saar at yahoo.com> wrote:
> Hello,
> I have installed the Intel fortran compiler and would like to link it
> with mpich2. I am running configure with device:ssm as it is a dual
> socket with quad-core xeons. I am using the following command
> ./configure -with-device=ch3:ssm -prefix=/usr/cluster/mpich2-1.2.1
> CC=gcc CXX=gcc F77=ifort F90=ifort
> I am getting an error saying "....configure: error: could not compile
> fortran test program"
> I have attached the config.log file.
> Appreciate your time and help.
> Thanks
> Raasik
> mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100210/782709fe/attachment-0001.htm>
