[mpich-discuss] mpd error
saar raas
raas_saar at yahoo.com
Mon Feb 8 00:43:20 CST 2010
I think I got past that error, I will update everybody soon.
raasik
--- On Mon, 2/8/10, saar raas <raas_saar at yahoo.com> wrote:
Subject: [mpich-discuss] mpd error
Date: Monday, February 8, 2010, 12:44 AM
Hello,
I am trying to install mpich2 on a 3 node cluster of quadcore processors with centos5.4 x64 version. I am getting error messages when I issue the mpd & command on the first node (head node). I have provided the path in the bash_profile file and do not get any error messages when I go through the list of commands provided in the install help file in pdf format. The error messages are as below;
[root at node01 ~]# mpd &
[1] 4046
[root at node01 ~]# node01_37116 (mpd_sockpair 240): connect -3 Temporary failure in name resolution
node01_37116 (mpd_sockpair 247): connect error with -3 Temporary failure in name resolution
mpd &
[2] 4048
[root at node01 ~]# An mpd is already running with console at
/tmp/mpd2.console_root on node01.
Start mpd with the -n option for a second mpd on same host.
[2]+ Exit 255 mpd
[root at node01 ~]# mpdallexit
[root at node01 ~]#
Please let me know if any additional info. is needed.
raasik
-----Inline Attachment Follows-----
mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100207/16fe0507/attachment.htm>
