[mpich-discuss] Questions about Installation
Roberto Neves Gonzaga
rnginfo at ig.com.br
Wed Dec 29 14:23:55 CST 2010
Dear Sir,
First I wish everyone a prosperous new year. I am setting up a Beowulf
cluster in virtual machine (VirtualBox) and I am using Fedora 13, as part of
a final project for my university end course, using the passing libraries
PVM and MPICH2 (version MPICH2-1.3.1). I have followed all the steps in your
Installer's Guide, and almost everything seems to be working. I could run
the example but just at the most master machine (front-end).
I have some questions and would like if possible that you give me some
explanations.
My final installation folder is: home/cluster/mpich2-install
The line: /home/cluster/mpich2-install
At the line c, what should I have to do: execute the line or I have to
increase the line in the file /.bash_profile or other file?
In the exemple mpiexec -f machinefile -n <number> ./examples/cpi I did not
understand what means machinefile I have to create some file informing the
hosts?
What is the correct procedure for that the MPI works on all machines in the
cluster?
In certain situations, using the command *mpirun* I get the answer down. What
does it mean? What should I do about it?
[proxy:0:0 at mestre]
HYDU_create_process(/home/cluster/mpich2-1.3.1/src/pm/hydra/utils/launch/launch.c:69):
execvp error on file cpi (No such file or directory)
Best regards
Roberto Neves Gonzaga, Rio de Janeiro, Brazil.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20101229/c99166aa/attachment.htm>
