[mpich-discuss] Upgrading GCC Compilers
Dave Goodell goodell at mcs.anl.gov
Mon Aug 30 10:47:03 CDT 2010
If the only thing you are upgrading is the compiler, you probably don't need to rebuild MPICH2, particularly since it would be a 4.x-->4.x change.  However, depending on how/where you install the new compiler, the mpicc/mpif77/etc compiler wrapper scripts may still point to the old compiler.
You can see the compile/link line that will be used by mpicc by running "mpicc -show".
-Dave
On Aug 30, 2010, at 5:27 AM CDT, saar raas wrote:
> Hello,
> I have installed mpich2 on centos 5.4 x64 and everything seems to be working fine. My current GCC compilers are 4.1.2 and I would like to upgrade to 4.4 or 4.5. I would like to know whether I will need to recompile/reinstall mpich2 after upgrading the GCC compilers.
> Thanks,
> Raasik
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
