[mpich-discuss] Configure error
Dave Goodell
goodell at mcs.anl.gov
Wed Aug 18 13:40:57 CDT 2010
I thought this sounded familiar. It's a bug we fixed a while back on the trunk, but never made it to the 1.2.x series: http://lists.mcs.anl.gov/pipermail/mpich-discuss/2010-February/006480.html
Basically, the problem is that we don't correctly handle spaces in many of the "precious" autoconf variables, especially CPPFLAGS. It was fixed on the trunk by r6220-6226.
1.3b1 shouldn't suffer from this problem, if you are willing to use it. I'll see if there's a way to back-port any of this to the 1.2.1 branch. The workaround I mentioned earlier might also still work for you, but you might hit a different set of related problems later on instead.
-Dave
On Aug 18, 2010, at 12:54 PM CDT, Dave Goodell wrote:
> Hmm... it looks like we have a bug in the configure stage somewhere, but I haven't found it yet. For some reason your CPPFLAGS argument is clobbering some internal additions to the CPPFLAGS, which confuses the nemesis sub-configure.
> You might be able to work around this by adding the following entries to your CPPFLAGS argument for now:
> -I/home/ssul/work/distros2/mpich2/mpich2-1.2.1p1/src/openpa/src
> -I${PWD}/src/openpa/src
> -Dave
> On Aug 18, 2010, at 11:28 AM CDT, Seung-Jin Sul wrote:
>> On 08/18/2010 12:16 PM, Dave Goodell wrote:
>>> Can you also send us the following two files from the build directory?
>>> config.log
>>> src/mpid/ch3/channels/nemesis/config.log
>>> Nemesis thinks that you don't have a working OpenPA configuration, but the OPA configure output seems OK to me. In particular, I'll need that second file to see why Nemesis doesn't like OPA's config.
>>> Otherwise, without seeing the logs, it seems like there's a chance it could be related to providing an "--exec-prefix" argument, since I don't think that we test that capability.
>>> -Dave
>>> On Aug 18, 2010, at 10:24 AM CDT, Seung-Jin Sul wrote:
>>>> Hi,
>>>> While I configured MPICH2, I found an error.
>>>> Could you please look into the c.txt I've attached?
>>>> Thanks.
>>>> Seung.
>>>> <c.txt>_______________________________________________
>>>> mpich-discuss mailing list
>>>> mpich-discuss at mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>> OK. I've attached them.
>> And I found the same error without "--exec-prefix ".
>> Seung.
>> <config.log><config.log>_______________________________________________
