[mpich-discuss] linux
sasha lambert
lambert.sasha at gmail.com
Fri Aug 13 10:09:34 CDT 2010
I initially used the gfortran binary provided by the HPC Mac OS X website
at http://hpc.sourceforge.net/ , which happens to be in 32-bit, and
therefore gives rise to the incompatibility issue.
A 64-bit version is available for Mac OS X at
http://gcc.gnu.org/wiki/GFortranBinaries#MacOS .
After this installation, the MPICH configure and make steps performed
smoothly.
Thanks for the help!
Sasha
On Fri, Aug 13, 2010 at 10:32 AM, Dave Goodell <goodell at mcs.anl.gov> wrote:
> You can usually run it between two different versions of Linux, for
> example, provided that both machines have the same type of processor. Also,
> both should be running either 64-bit or 32-bit, not a mix.
> Windows+Linux is theoretically possible (given the same restrictions as
> above), but I personally wouldn't bother with it. It's probably more pain
> than it's worth and may not work in the end.
> -Dave
> On Aug 11, 2010, at 11:00 PM CDT, lichaoyang wrote:
> > I want to know whether I can run MPICH2 program in two different opearing
> system at the same time. (my MPICH2 is 2-1.2.1.tar.gz).
> > 您想拥有和网易免费邮箱一样强大的软件吗? _______________________________________________
> > mpich-discuss mailing list
> > mpich-discuss at mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100813/96f442fb/attachment.htm>
