[mpich-discuss] How can I compile the documents of source code?
Rajeev Thakur
thakur at mcs.anl.gov
Mon Sep 21 14:29:36 CDT 2009
> but Many files in the directory 'doc' of the source code can not be
> found, eg. design file.
> How can I compile all the documents ?
Run make in those directories.
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of wanneng
> Sent: Sunday, September 20, 2009 11:28 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] How can I compile the documents of
> source code?
> I compiled and install the source code with command like this :
> 1 ./configure ./configure --enable-g=dbg --prefix=/usr/local
> --pdfdir=/home/wanneng/usr/share/doc/
> 2 make
> 3 make install
> After install, I could not find the design files in
> /usr/local/share/doc
> and /home/wanneng/usr/share/doc
> only in the directory /usr/local/share there are files:
> index.htm install.pdf jumpshot-4 logging.pdf openpa smpd_pmi.pdf
> user.pdf www1 www3 www4
