[mpich-discuss] How can I compile the documents of source code?
wanneng yangguosdxl at gmail.com
Sun Sep 20 23:27:40 CDT 2009
I compiled and install the source code with command like this :
1 ./configure  ./configure --enable-g=dbg --prefix=/usr/local
--pdfdir=/home/wanneng/usr/share/doc/
2 make
3 make install
After install, I could not find the design files in /usr/local/share/doc
and /home/wanneng/usr/share/doc
only in the directory /usr/local/share there are files:
index.htm  install.pdf  jumpshot-4  logging.pdf  openpa  smpd_pmi.pdf
user.pdf  www1  www3  www4
but Many files in the directory 'doc' of the source code can not be
found, eg. design file.
How can I compile all the documents ?
