[mpich-discuss] COMM_SELF and collective IO
burlen
burlen.loring at gmail.com
Fri Oct 16 23:56:23 CDT 2009
Actually, not quite. But if we can put that aside for the moment. Is
there a significant downside to using COMM_SELF + MPI_File_read_all
compared to just MPI_File_read?
Rajeev Thakur wrote:
> You will have the same if you use COMM_SELF for one and COMM_WORLD for
> the other. You don't want to use COMM_SELF for both.
>> -----Original Message-----
>> From: mpich-discuss-bounces at mcs.anl.gov
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of burlen
>> Sent: Friday, October 16, 2009 7:22 PM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: Re: [mpich-discuss] COMM_SELF and collective IO
>> I could then I will have to have two codes with only a one
>> line difference.
>>> Why don't you just use MPI_File_read instead?
>>> Rajeev
>>>> Sent: Friday, October 16, 2009 5:39 PM
>>>> Subject: [mpich-discuss] COMM_SELF and collective IO
>>>> I have an io code that uses the subarray type. I use the
>> collective
>>>> IO function, MPI_File_read_all. Now, I have a use case where each
>>>> process needs to read independently of the others. What I
>> am tempted
>>>> to do is change the communicator to MPI_COMM_SELF and use the same
>>>> code. I suspect that this is a bad idea. Is it?
>>>> _______________________________________________
>>>> mpich-discuss mailing list
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
