[mpich-discuss] COMM_SELF and collective IO
Rajeev Thakur
thakur at mcs.anl.gov
Sat Oct 17 08:08:32 CDT 2009
COMM_SELF means all=1. So MPI_File_read_all is equivalent to
MPI_File_read in that case.
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of burlen
> Sent: Friday, October 16, 2009 11:56 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] COMM_SELF and collective IO
> Actually, not quite. But if we can put that aside for the
> moment. Is there a significant downside to using COMM_SELF +
> MPI_File_read_all compared to just MPI_File_read?
> Rajeev Thakur wrote:
> > You will have the same if you use COMM_SELF for one and
> COMM_WORLD for
> > the other. You don't want to use COMM_SELF for both.
> >> Sent: Friday, October 16, 2009 7:22 PM
> >> I could then I will have to have two codes with only a one line
> >> difference.
> >>> Why don't you just use MPI_File_read instead?
> >>> Rajeev
> >>>> Sent: Friday, October 16, 2009 5:39 PM
> >>>> Subject: [mpich-discuss] COMM_SELF and collective IO
> >>>> I have an io code that uses the subarray type. I use the
> >> collective
> >>>> IO function, MPI_File_read_all. Now, I have a use case
> where each
> >>>> process needs to read independently of the others. What I
> >> am tempted
> >>>> to do is change the communicator to MPI_COMM_SELF and
> use the same
> >>>> code. I suspect that this is a bad idea. Is it?
> >>>> _______________________________________________
> >>>> mpich-discuss mailing list
> >>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
