[mpich-discuss] COMM_SELF and collective IO
Rajeev Thakur
thakur at mcs.anl.gov
Fri Oct 16 19:41:34 CDT 2009
You will have the same if you use COMM_SELF for one and COMM_WORLD for
the other. You don't want to use COMM_SELF for both.
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of burlen
> Sent: Friday, October 16, 2009 7:22 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] COMM_SELF and collective IO
> I could then I will have to have two codes with only a one
> line difference.
> Rajeev Thakur wrote:
> > Why don't you just use MPI_File_read instead?
> > Rajeev
> >> Sent: Friday, October 16, 2009 5:39 PM
> >> Subject: [mpich-discuss] COMM_SELF and collective IO
> >> I have an io code that uses the subarray type. I use the
> collective
> >> IO function, MPI_File_read_all. Now, I have a use case where each
> >> process needs to read independently of the others. What I
> am tempted
> >> to do is change the communicator to MPI_COMM_SELF and use the same
> >> code. I suspect that this is a bad idea. Is it?
> >> _______________________________________________
> >> mpich-discuss mailing list
> >> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
