[mpich-discuss] mpich2 configure error
Jayesh Krishna
jayesh at mcs.anl.gov
Wed Nov 25 11:42:17 CST 2009
If you are using Cygwin on windows you can use either mpd or smpd.
-Jayesh
----- Original Message -----
To: Gnananesan-Antonyraj at utc.edu
Cc: mpich-discuss at mcs.anl.gov
Sent: Tuesday, November 24, 2009 9:12:09 PM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] mpich2 configure error
Also, for windows builds, you'll need to use the SMPD process manager:
% ./configure --with-pm=smpd --with-pmi=smpd --prefix=c:/install
--enable-timer-type=gettimeofday
-- Pavan
On 11/24/2009 09:08 PM, Nesan Antonyraj wrote:
> The configure and make steps completed successfully. 'make install' got one error. Attached is the mi.txt output file. Please check and advise.
> thanks,
> Nesan.
> -----Original Message-----
> From: Pavan Balaji <balaji at mcs.anl.gov>
> Date: Tue, 24 Nov 2009 20:00:23 -0600
> Hmm.. It looks like you have clock_gettime on your system, but it's not
> a part of librt.a. This is partly an error in configure itself, which
> I'll poke into.
> In the meanwhile, can you configure with
> --enable-timer-type=gettimeofday and see if that gets you past this problem?
> Alternatively, we provide windows binaries on our website:
> http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads
> if you want to use those instead.
> -- Pavan
> On 11/24/2009 07:49 PM, Nesan Antonyraj wrote:
>> Thanks Mr. Balaji. Attached is the configure output text c.txt. I am configuring within cygwin with the command,
>> c:/nesan/libraries/mpich2-1.2.1/configure -prefix=c:/build 2>&1 | tee c.txt
>> thanks,
>> Nesan.
>> To: Gnananesan-Antonyraj at utc.edu, mpich-discuss at mcs.anl.gov
>> Date: Tue, 24 Nov 2009 19:45:38 -0600
>> Can you send us the entire configure output? It's very hard to say what
>> the problem is based on just the below information.
>> for csh and tcsh:
>> ./configure --prefix=/home/you/mpich2-install |& tee c.txt
>> for bash and sh:
>> ./configure --prefix=/home/you/mpich2-install 2>&1 | tee c.txt
>> -- Pavan
>> On 11/24/2009 07:42 PM, Nesan Antonyraj wrote:
>>> Hello,
>>> I am getting the error below when configuring mpich2-1.2.1. Please advise.
>>> configure: error: Requested timer clock_gettime (POSIX) is not available
>>> thanks,
>>> Nesan.
>>> _______________________________________________
>>> mpich-discuss mailing list
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Pavan Balaji
http://www.mcs.anl.gov/~balaji
