[mpich-discuss] mpich2 configure error
Pavan Balaji balaji at mcs.anl.gov
Tue Nov 24 21:12:09 CST 2009
Also, for windows builds, you'll need to use the SMPD process manager:
% ./configure --with-pm=smpd --with-pmi=smpd --prefix=c:/install
--enable-timer-type=gettimeofday
 -- Pavan
On 11/24/2009 09:08 PM, Nesan Antonyraj wrote:
> The configure and make steps completed successfully.  'make install'  got one error.  Attached is the mi.txt output file.  Please check and advise.
> thanks,
> Nesan.
> -----Original Message-----
> From: Pavan Balaji <balaji at mcs.anl.gov>
> To: Gnananesan-Antonyraj at utc.edu
> Date: Tue, 24 Nov 2009 20:00:23 -0600
> Subject: Re: [mpich-discuss] mpich2 configure error
> Hmm.. It looks like you have clock_gettime on your system, but it's not
> a part of librt.a. This is partly an error in configure itself, which
> I'll poke into.
> In the meanwhile, can you configure with
> --enable-timer-type=gettimeofday and see if that gets you past this problem?
> Alternatively, we provide windows binaries on our website:
> http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads
> if you want to use those instead.
>  -- Pavan
> On 11/24/2009 07:49 PM, Nesan Antonyraj wrote:
>> Thanks Mr. Balaji.  Attached is the configure output text c.txt.  I am configuring within cygwin with the command,
>> c:/nesan/libraries/mpich2-1.2.1/configure -prefix=c:/build 2>&1 | tee c.txt
>> thanks,
>> Nesan.
>> To: Gnananesan-Antonyraj at utc.edu, mpich-discuss at mcs.anl.gov
>> Date: Tue, 24 Nov 2009 19:45:38 -0600
>> Can you send us the entire configure output? It's very hard to say what
>> the problem is based on just the below information.
>>     for csh and tcsh:
>>       ./configure --prefix=/home/you/mpich2-install |& tee c.txt
>>     for bash and sh:
>>       ./configure --prefix=/home/you/mpich2-install 2>&1 | tee c.txt
>>  -- Pavan
>> On 11/24/2009 07:42 PM, Nesan Antonyraj wrote:
>>> Hello,
>>> I am getting the error below when configuring mpich2-1.2.1.  Please advise.
>>> configure: error: Requested timer clock_gettime (POSIX) is not available
>>> thanks,
>>> Nesan.
>>> _______________________________________________
>>> mpich-discuss mailing list
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Pavan Balaji
http://www.mcs.anl.gov/~balaji
