[mpich-discuss] Need some help getting mpich to work
Rajeev Thakur thakur at mcs.anl.gov
Mon Nov 23 13:28:38 CST 2009
Can you try the latest release 1.2.1?
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Hung-Hsun Su
> Sent: Monday, November 23, 2009 11:16 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] Need some help getting mpich to work
> Hi,
> I was wondering if anyone can help me figure out why my MPICH2
> installation isn't working correctly. I've downloaded the
> v1.2 version,
> configured using "configure
> --prefix=/home/su/software/mpich2-1.2", make
> and make install and everything seemed fine (I've attached the 3 txt
> output from configure, make and make install which shows no
> error).  I
> then tried to see if my installation is working correctly by
> running the
> mpich-test suite (result given in summary.xml) and some of the tests
> failed (collective).  Does anyone know what might be the cause of my
> problem? Thanks.
> System spec:
> 32 nodes Quad-core Xeon cluster
> Linux version 2.6.9-55.0.2.ELsmp (mockbuild at builder6.centos.org) (gcc
> version 3.4.6 20060404 (Red Hat 3.4.6-8)) #1 SMP Tue Jun 26
> 14:14:47 EDT
> 2007
> Hung-Hsun
> Sincerely,
> Hung-Hsun Su
> Ph.D. Student, UPC Group Leader, Research Assistant, Teaching
> Assistant
> High-performance Computing and Simulation (HCS) Research Laboratory
> Dept. of Electrical and Computer Engineering , University of Florida,
> Gainesville, FL 32611-6200
> Email: su at hcs.ufl.edu, hunghsun at ufl.edu
