[mpich-discuss] Need some help getting mpich to work
Hung-Hsun Su
su at hcs.ufl.edu
Mon Nov 23 11:16:01 CST 2009
I was wondering if anyone can help me figure out why my MPICH2
installation isn't working correctly. I've downloaded the v1.2 version,
configured using "configure --prefix=/home/su/software/mpich2-1.2", make
and make install and everything seemed fine (I've attached the 3 txt
output from configure, make and make install which shows no error). I
then tried to see if my installation is working correctly by running the
mpich-test suite (result given in summary.xml) and some of the tests
failed (collective). Does anyone know what might be the cause of my
problem? Thanks.
System spec:
32 nodes Quad-core Xeon cluster
Linux version 2.6.9-55.0.2.ELsmp (mockbuild at builder6.centos.org) (gcc
version 3.4.6 20060404 (Red Hat 3.4.6-8)) #1 SMP Tue Jun 26 14:14:47 EDT
Hung-Hsun
Sincerely,
Hung-Hsun Su
Ph.D. Student, UPC Group Leader, Research Assistant, Teaching Assistant
High-performance Computing and Simulation (HCS) Research Laboratory
Dept. of Electrical and Computer Engineering , University of Florida,
Gainesville, FL 32611-6200
Email: su at hcs.ufl.edu, hunghsun at ufl.edu
Type: text/xml
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091123/9ddd95f2/attachment-0001.bin>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091123/9ddd95f2/attachment-0003.txt>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091123/9ddd95f2/attachment-0004.txt>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091123/9ddd95f2/attachment-0005.txt>
