[mpich-discuss] ????: how to connect MPI_Send with CH3_isend
hu yaohui loki2441 at gmail.com
Sun Nov 15 19:11:38 CST 2009
thank you very much!
yes ,you are right! i want the processes to communicate that way.
i really appreciate your help,i'll give it a shot anyhow,i recently read
something about mpich/madeleine,i hope that helps.
thank you very much again!
                                                     --best wishes
                                                     --Yaohui Hu
2009/11/15 Darius Buntinas <buntinas at mcs.anl.gov>
> Do you mean use sockets to communicate between processes 1 and
> 2, but use IB to communicate between processes 1 and 3?
> We intend to support this, but all the pieces are not there yet.
> There are function pointer tables for each netmod.
> If you take a look at MPID_nem_vc_init(), you'll see where
> MPID_nem_netmod_func->vc_init(vc) is called to set the function
> pointers for the various communication operations used when
> sending a message over a particular network module.
> Currently MPID_nem_netmod_func is set globally, so that all
> internode vcs use the same netmod.  In order to use different
> netmods for different vcs, you'll have call the vc_init() of
> the netmod you want to use on that vc.
> You'll see other places where MPID_nem_netmod_func is referenced
> and you'll have to fix those so either they call the function
> for the netmod associated with that vc, or (e.g., in the case of
> poll or finalize) you'll need to call the function for all active
> netmods.
> -d
> On 11/14/2009 01:07 AM, hu yaohui wrote:
> > Thank you very much ,i am just wondering if i implement two internode
> > communication channel,can i control some kinds of messge goes through
> > one channel while other messge goes through goes through other
> > channel(not one kind of message goes through different channels) thank
> > you very much!
> > On Sat, Nov 14, 2009 at 2:32 AM, Rajeev Thakur <thakur at mcs.anl.gov
> > <mailto:thakur at mcs.anl.gov>> wrote:
> >     If you use the default Nemesis channel (ch3:nemesis), communication
> >     within a node goes over shared memory and across nodes over some
> >     communication channel.
> >     Rajeev
> >         *From:* mpich-discuss-bounces at mcs.anl.gov
> >         <mailto:mpich-discuss-bounces at mcs.anl.gov>
> >         [mailto:mpich-discuss-bounces at mcs.anl.gov
> >         <mailto:mpich-discuss-bounces at mcs.anl.gov>] *On Behalf Of *hu
> yaohui
> >         *Sent:* Friday, November 13, 2009 3:13 AM
> >         *To:* mpich-discuss at mcs.anl.gov <mailto:
> mpich-discuss at mcs.anl.gov>
> >         *Subject:* Re: [mpich-discuss]´ð¸´: how to connect MPI_Send with
> >         CH3_isend
> >            I would really appreciate,if you can give me some detail
> >         steps from the implemention of these functions to deploy the
> >         mpich2 on my clusters! (such as how to modify the configure file
> >         sth like that.)
> >             i did a test yesterday ,i install the mpich2 three times
> >         ,and then check the make
> >         output,chosse ./configure
> --with-device=ch3:sock,--with-device=ch3:sctp
> >         and default,
> >         does these device means the internode communication channel? and
> >         the default intranode communication channel is shared-memory and
> >         cann't be modified?
> >         best wishes!
> >         2009/11/13 Darius Buntinas <buntinas at mcs.anl.gov
> >         <mailto:buntinas at mcs.anl.gov>>
> >             The ability to use different networks for different
> >             destinations is a feature we intend to add, but it's not
> >             yet implemented.  Nemesis does use shared-memory
> communication
> >             for intranode communication and the network for internode.
> >             There are several internal interfaces for porting MPICH2 to
> new
> >             platforms or interconnects.  This paper has a description of
> the
> >             interfaces:
> http://www.mcs.anl.gov/~buntinas/papers/europvmmpi06-nemesis.pdf
> >             If you're interested in porting MPICH2 to a new interconnect,
> >             you should write a nemesis network module.  The API is
> described
> >             here:
> http://wiki.mcs.anl.gov/mpich2/index.php/Nemesis_Network_Module_API
> >             I hope this helps,
> >             -d
> >             On 11/12/2009 11:29 PM, yaohui wrote:
> >             > Thank you very much!
> >             >       Finally I got a response!
> >             > I am doing some researches on adding HT(HyperTransport)
> >             into mpich2,I am
> >             > just wandering when we configure the mpich2 with
> >             >                       ./configure ¨Cwith-device=ch3:sock
> >             (ch3:nemesis)
> >             > that means we definitely select one network as the channel
> >             to communicate,
> >             > but if there are any possibilities that you can dynamic
> >             > control the network we use ,sometimes messages go through
> >             Ethernet,
> >             > sometimes go through IB. could you give me some materials
> >             > to understand what's the difference between
> ~/ch3/channel/sock
> >             > ,~/ch3/channel/sctp
> >             ~,~/ch3/channel/nemesis/nemesis/net_mod/tcp_module
> >             > , ~/ch3/channel/nemesis/nemesis/net_mod/sctp_module,
> >             > ~/ch3/channel/nemesis/nemesis/net_mod/ib_module
> >             > Thank you again!
> >             > Best Wishes!
> >             > -----ÓʼþÔ­¼þ-----
> >             > ·¢¼þÈË: mpich-discuss-bounces at mcs.anl.gov
> >             <mailto:mpich-discuss-bounces at mcs>.
> >             > anl.gov <http://anl.gov/>] ´ú±í Darius Buntinas
> >             > ·¢ËÍʱ¼ä: 2009Äê11ÔÂ12ÈÕ 23:30
> >             > ÊÕ¼þÈË: mpich-discuss at mcs.anl.gov
> >             <mailto:mpich-discuss at mcs.anl.gov>
> >             > Ö÷Ìâ: Re: [mpich-discuss] how to connect MPI_Send with
> >             CH3_isend
> >             > The best way to understand what happens is to step through
> >             the calls
> >             > with a debugger.  The channel is selected in the configure
> >             step, and
> >             > only that channel will be compiled, so there will be only
> >             one copy of
> >             > ch3_isend in the binary.
> >             > -d
> >             > On 11/12/2009 05:54 AM, hu yaohui wrote:
> >             >> hi guys!
> >             >>     Could someone tell me the detail calling flow from
> >             MPI_Send() to
> >             >> CH3_isend()?
> >             >>     How to control which CH3_isend() is called between
> >             sock,sctp and
> >             >> shm? thank you very much!
> >             > best
> >             >> wishes!
> >             >> loki!
> >             >> _______________________________________________
> >             >> mpich-discuss mailing list
> >             >> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> >             mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.gov>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20091116/8431f98f/attachment.htm>
