[mpich-discuss] ????: how to connect MPI_Send with CH3_isend
Darius Buntinas
buntinas at mcs.anl.gov
Sun Nov 15 09:56:13 CST 2009
Do you mean use sockets to communicate between processes 1 and
2, but use IB to communicate between processes 1 and 3?
We intend to support this, but all the pieces are not there yet.
There are function pointer tables for each netmod.
If you take a look at MPID_nem_vc_init(), you'll see where
MPID_nem_netmod_func->vc_init(vc) is called to set the function
pointers for the various communication operations used when
sending a message over a particular network module.
Currently MPID_nem_netmod_func is set globally, so that all
internode vcs use the same netmod. In order to use different
netmods for different vcs, you'll have call the vc_init() of
the netmod you want to use on that vc.
You'll see other places where MPID_nem_netmod_func is referenced
and you'll have to fix those so either they call the function
for the netmod associated with that vc, or (e.g., in the case of
poll or finalize) you'll need to call the function for all active
netmods.
-d
On 11/14/2009 01:07 AM, hu yaohui wrote:
> Thank you very much ,i am just wondering if i implement two internode
> communication channel,can i control some kinds of messge goes through
> one channel while other messge goes through goes through other
> channel(not one kind of message goes through different channels) thank
> you very much!
> On Sat, Nov 14, 2009 at 2:32 AM, Rajeev Thakur <thakur at mcs.anl.gov
> <mailto:thakur at mcs.anl.gov>> wrote:
> If you use the default Nemesis channel (ch3:nemesis), communication
> within a node goes over shared memory and across nodes over some
> communication channel.
> Rajeev
> *From:* mpich-discuss-bounces at mcs.anl.gov
> <mailto:mpich-discuss-bounces at mcs.anl.gov>
> [mailto:mpich-discuss-bounces at mcs.anl.gov
> <mailto:mpich-discuss-bounces at mcs.anl.gov>] *On Behalf Of *hu yaohui
> *Sent:* Friday, November 13, 2009 3:13 AM
> *To:* mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.gov>
> *Subject:* Re: [mpich-discuss]´ð¸´: how to connect MPI_Send with
> CH3_isend
> thank you very much!
> I would really appreciate,if you can give me some detail
> steps from the implemention of these functions to deploy the
> mpich2 on my clusters! (such as how to modify the configure file
> sth like that.)
> i did a test yesterday ,i install the mpich2 three times
> ,and then check the make
> output,chosse ./configure --with-device=ch3:sock,--with-device=ch3:sctp
> and default,
> does these device means the internode communication channel? and
> the default intranode communication channel is shared-memory and
> cann't be modified?
> best wishes!
> 2009/11/13 Darius Buntinas <buntinas at mcs.anl.gov
> <mailto:buntinas at mcs.anl.gov>>
> The ability to use different networks for different
> destinations is a feature we intend to add, but it's not
> yet implemented. Nemesis does use shared-memory communication
> for intranode communication and the network for internode.
> There are several internal interfaces for porting MPICH2 to new
> platforms or interconnects. This paper has a description of the
> interfaces:
> http://www.mcs.anl.gov/~buntinas/papers/europvmmpi06-nemesis.pdf
> If you're interested in porting MPICH2 to a new interconnect,
> you should write a nemesis network module. The API is described
> here:
> http://wiki.mcs.anl.gov/mpich2/index.php/Nemesis_Network_Module_API
> I hope this helps,
> -d
> On 11/12/2009 11:29 PM, yaohui wrote:
> > Thank you very much!
> > Finally I got a response!
> > I am doing some researches on adding HT(HyperTransport)
> into mpich2,I am
> > just wandering when we configure the mpich2 with
> > ./configure ¨Cwith-device=ch3:sock
> (ch3:nemesis)
> > that means we definitely select one network as the channel
> to communicate,
> > but if there are any possibilities that you can dynamic
> > control the network we use ,sometimes messages go through
> Ethernet,
> > sometimes go through IB. could you give me some materials
> > to understand what's the difference between ~/ch3/channel/sock
> > ,~/ch3/channel/sctp
> ~,~/ch3/channel/nemesis/nemesis/net_mod/tcp_module
> > , ~/ch3/channel/nemesis/nemesis/net_mod/sctp_module,
> > ~/ch3/channel/nemesis/nemesis/net_mod/ib_module
> > Thank you again!
> > Best Wishes!
> > -----ÓʼþÔ¼þ-----
> > ·¢¼þÈË: mpich-discuss-bounces at mcs.anl.gov
> <mailto:mpich-discuss-bounces at mcs>.
> > anl.gov <http://anl.gov/>] ´ú±í Darius Buntinas
> > ·¢ËÍʱ¼ä: 2009Äê11ÔÂ12ÈÕ 23:30
> > ÊÕ¼þÈË: mpich-discuss at mcs.anl.gov
> > Ö÷Ìâ: Re: [mpich-discuss] how to connect MPI_Send with
> CH3_isend
> > The best way to understand what happens is to step through
> the calls
> > with a debugger. The channel is selected in the configure
> step, and
> > only that channel will be compiled, so there will be only
> one copy of
> > ch3_isend in the binary.
> > -d
> > On 11/12/2009 05:54 AM, hu yaohui wrote:
> >> hi guys!
> >> Could someone tell me the detail calling flow from
> MPI_Send() to
> >> CH3_isend()?
> >> How to control which CH3_isend() is called between
> sock,sctp and
> >> shm? thank you very much!
> > best
> >> wishes!
> >> loki!
> >> _______________________________________________
> >> mpich-discuss mailing list
> >> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
