[mpich-discuss] Facing problem while using MPI_File_set_view
Christina Patrick
christina.subscribes at gmail.com
Thu May 28 13:28:21 CDT 2009
Yeah sure. Please go ahead.
In case you'll are able to figure out where the problem lies, please
do let me know so that I can download the patch.
Also, could you please tell me how to download the CVS version? And,
is the problem going away with the latest mpich CVS or pvfs CVS
versions?
Thanks and Regards,
Christina.
On Thu, May 28, 2009 at 8:43 AM, Rob Latham <robl at mcs.anl.gov> wrote:
> On Wed, May 27, 2009 at 06:04:28PM -0400, Christina Patrick wrote:
>> Thank you very much. Since the API MPI_Type_create_subarray() is very
>> easy to use as compared to other API's used to create data types in
>> MPI, I would really appreciate a solution to this problem.
>> FYI: I am using pvfs 2.8.0.
>> I will check it out with pvfs2.8.1 and keep you posted.
> I think 2.8.1 will also crash. You will probably have to download the
> CVS version if you want things to work right now. We can work on
> figuring out just what changed between 2.8.1 and recent CVS.
> Can we add your program to the PVFS testsuite?
> ==rob
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
