[mpich-discuss] Facing problem while using MPI_File_set_view
Rob Latham robl at mcs.anl.gov
Thu May 28 07:43:54 CDT 2009
On Wed, May 27, 2009 at 06:04:28PM -0400, Christina Patrick wrote:
> Thank you very much. Since the API MPI_Type_create_subarray() is very
> easy to use as compared to other API's used to create data types in
> MPI, I would really appreciate a solution to this problem.
> FYI: I am using pvfs 2.8.0.
> I will check it out with pvfs2.8.1 and keep you posted.
I think 2.8.1 will also crash.  You will probably have to download the
CVS version if you want things to work right now.  We can work on
figuring out just what changed between 2.8.1 and recent CVS.
Can we add your program to the PVFS testsuite?
==rob
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
