[mpich-discuss] question about MPICH2 installation on SUN
Jim Langston
Jim.Langston at Sun.COM
Thu May 21 08:59:19 CDT 2009
Looking at the config.log, I see a version of gcc which is
built for Solaris 9, but the header shows that system is Solaris 10,
if you have installed the companion CD for Solaris 10, you should
see gcc and g++ residing in /usr/sfw/bin
Jim
Shangli Wu wrote:
> thanks
> Shangli
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Dave Goodell
> Sent: Wednesday, May 20, 2009 3:43 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] question about MPICH2 installation on SUN
> Looking at your config.log it seems that your pthread.h header is broken
> even for trivial programs. Ideally this shouldn't be a deal- breaker
> for mpich2, but something isn't right in the build system and the broken
> pthread.h ends up getting included anyway. I'll file this bug as a
> ticket so we can track it, but there probably isn't anything we can do
> for you in the short term. Can you work with your system administrator
> to figure out why the system pthread.h doesn't work?
> This might be an incompatibility between the version of gcc that you
> have installed and the system headers. You might try building with the
> system compilers instead (configure CC=cc CXX=CC).
> -Dave
> On May 20, 2009, at 2:09 PM, Shangli Wu wrote:
>> I tried the version 1.1. It has same error due to "/usr/include/
>> pthread.h:299: syntax error defore '*' token"
>> shangli
>> ] On Behalf Of Rajeev Thakur
>> Sent: Wednesday, May 20, 2009 1:31 PM
>> Could you try the release candidate for 1.1, which is also available
>> from the MPICH2 downloads page?
>> Rajeev
>> ] On Behalf Of Shangli Wu
>> Sent: Wednesday, May 20, 2009 11:18 AM
>> Subject: [mpich-discuss] question about MPICH2 installation on SUN
>> Hi,
>> I tried to install MPICH2 on different machines. I had trouble to go
>> through the installation on SUN (I was able to make it working on
>> Linux). Here are my configure.log and make.log. Could someone
>> help me about this?
>> Thanks
>> Shangli Wu
Jim Langston
Sun Microsystems, Inc.
(513) 702-4741 (Cell)
(877) 854-5583 (AccessLine)
AIM: jl9594
jim.langston at sun.com
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090521/d1616679/attachment.htm>
