[mpich-discuss] [PATCH] Issue 5486: Nobody checks the return code from "MTest_Start_thread()".
Joe Ratterman
jratt0 at gmail.com
Thu May 21 16:39:41 CDT 2009
BGP has a maximum of 3 threads that can be created (SMP mode), but
sometimes only 1 (DUAL mode). Because some tests try to create more
than 3 threads, pthread_create() will fail. However, nobody checks
that, so the tests time-out.
This adds an abort: if something absolutely *must* happen, you cannot
let it silently fail.
mpich2/test/mpi/threads/pt2pt/testlist | 6 +++---
mpich2/test/mpi/threads/util/mtestthread.c | 9 +++++++--
2 files changed, 10 insertions(+), 5 deletions(-)
diff --git a/mpich2/test/mpi/threads/pt2pt/testlist b/mpich2/test/mpi/threads/pt2pt/testlist
index d62e8c7..c53b354 100644
--- a/mpich2/test/mpi/threads/pt2pt/testlist
+++ b/mpich2/test/mpi/threads/pt2pt/testlist
@@ -2,8 +2,8 @@ threaded_sr 2
alltoall 4
sendselfth 1
multisend 2
-multisend2 5
-multisend3 5
-multisend4 5
+# multisend2 5 # This test uses too many threads
+# multisend3 5 # This test uses too many threads
+# multisend4 5 # This test uses too many threads
greq_wait 1
greq_test 1
diff --git a/mpich2/test/mpi/threads/util/mtestthread.c b/mpich2/test/mpi/threads/util/mtestthread.c
index b171785..af01643 100644
--- a/mpich2/test/mpi/threads/util/mtestthread.c
+++ b/mpich2/test/mpi/threads/util/mtestthread.c
@@ -60,7 +60,6 @@ int MTest_Join_threads( void ){
int MTest_Start_thread(MTEST_THREAD_RETURN_TYPE (*fn)(void *p),void *arg)
int err;
- pthread_t thread;
pthread_attr_t attr;
pthread_attr_init(&attr);
pthread_attr_setdetachstate(&attr, PTHREAD_CREATE_JOINABLE);
@@ -71,7 +70,13 @@ int MTest_Start_thread(MTEST_THREAD_RETURN_TYPE (*fn)(void *p),void *arg)
return 1;
err = pthread_create(threads+nthreads, &attr, fn, arg);
- if (!err) nthreads++;
+ if (!err)
+ nthreads++;
+ else
+ fprintf(stderr, "Failed to create thread calling func %p with arg %p\n", fn, arg);
+ abort();
pthread_attr_destroy(&attr);
return err;
1.6.3.2.gbfc07d5
