[mpich-discuss] SMP and mpd.hosts
Torquil Macdonald Sørensen
torquil at gmail.com
Tue Jun 30 11:23:37 CDT 2009
Torquil Macdonald Sørensen wrote:
> Hi all,
> I would like to ask for some help concerning the use of MPICH2 1.1 on a
> dual-core machine with Linux. My mpich2 innstallation uses the nemesis
> communication device, which I thought was able to utilise both cores, in
> addition to communicate through the network.
> From before (maybe from mpich1?) I had a mpd.hosts file with the
> following syntax:
> dagda.uio.no:2
> #styx.uio.no:2
> where the :2 was to indicate the number of CPUS. styx.uio.no is
> commented out because this time I want two processes to run on
> dagda.uio.no. But I am no longer sure of this syntax since I cannot find
> it in the documentation. I was hoping that the following would work:
> $ mpdboot -n 2
> $ mpiexec -n 2 ./Executable
> However, mpdboot complains:
> "totalnum=2 numhosts=1
> there are not enough hosts on which to start all processes"
> What it the common method to run a program so that it will be able to
> distribute itself across several cpu-cores in one machine, and also
> across the network, if I e.g. decomment styx.uio.no and use -n 4 in the
> above commands?
> Best regards
> Torquil Sørensen
It seems to be possible to get two processes by using "mpdboot -1 -n 2".
I guess that means that it starts more than one mpd. In that case
"mpiexec -n prog" works. So I guess I was suffering a limitation of max
one process per mpd?
-Torquil
