[mpich-discuss] SMP and mpd.hosts
Torquil Macdonald Sørensen torquil at gmail.com
Tue Jun 30 11:01:01 CDT 2009
Hi all,
I would like to ask for some help concerning the use of MPICH2 1.1 on a
dual-core machine with Linux. My mpich2 innstallation uses the nemesis
communication device, which I thought was able to utilise both cores, in
addition to communicate through the network.
 From before (maybe from mpich1?) I had a mpd.hosts file with the
following syntax:
dagda.uio.no:2
#styx.uio.no:2
where the :2 was to indicate the number of CPUS. styx.uio.no is
commented out because this time I want two processes to run on
dagda.uio.no. But I am no longer sure of this syntax since I cannot find
it in the documentation. I was hoping that the following would work:
$ mpdboot -n 2
$ mpiexec -n 2 ./Executable
However, mpdboot complains:
"totalnum=2  numhosts=1
there are not enough hosts on which to start all processes"
What it the common method to run a program so that it will be able to
distribute itself across several cpu-cores in one machine, and also
across the network, if I e.g. decomment styx.uio.no and use -n 4 in the
above commands?
Best regards
Torquil Sørensen
