[mpich-discuss] Problem with mpich2
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Thu Jun 25 14:00:18 CDT 2009
    Also make sure that you have the latest stable version, 1.1, of MPICH2
(http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=dow
nloads)
Jayesh
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Rajeev Thakur
Sent: Thursday, June 25, 2009 12:48 PM
Subject: Re: [mpich-discuss] Problem with mpich2
Can you send us a small test case that reproduces the problem?
Rajeev
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Suman Vajjala
Sent: Thursday, June 25, 2009 5:32 AM
Subject: [mpich-discuss] Problem with mpich2
 I am running a parallel code on a 10 node SMP cluster. The code runs for
sometime after which I get the following error
Fatal error in MPI_Type_contiguous: Other MPI error, error stack:
MPI_Type_contiguous(120): MPI_Type_contiguous(count=253,
MPI_DOUBLE_PRECISION, new_type_p=0xbfd42800) failed
MPID_Type_contiguous(44): Out of memory
[cli_6]: aborting job:
However, when I run the code on other cluster with mpich 1 as the
programming environment, the code runs smoothly.
Regards
Suman Vajjala
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090625/692d7530/attachment.htm>
