[mpich-discuss] Problem with mpich2
    Rajeev Thakur
    thakur at mcs.anl.gov
    Thu Jun 25 12:48:13 CDT 2009
Can you send us a small test case that reproduces the problem?
Rajeev
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Suman Vajjala
Sent: Thursday, June 25, 2009 5:32 AM
Subject: [mpich-discuss] Problem with mpich2
 I am running a parallel code on a 10 node SMP cluster. The code runs
for sometime after which I get the following error
Fatal error in MPI_Type_contiguous: Other MPI error, error stack:
MPI_Type_contiguous(120): MPI_Type_contiguous(count=253,
MPI_DOUBLE_PRECISION, new_type_p=0xbfd42800) failed
MPID_Type_contiguous(44): Out of memory
[cli_6]: aborting job:
However, when I run the code on other cluster with mpich 1 as the
programming environment, the code runs smoothly.
Regards
Suman Vajjala
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090625/b5e9aa6f/attachment.htm>
