[mpich-discuss] Problem with mpich2
    Suman Vajjala
    suman.geek at gmail.com
    Thu Jun 25 05:31:34 CDT 2009
 I am running a parallel code on a 10 node SMP cluster. The code runs for
sometime after which I get the following error
Fatal error in MPI_Type_contiguous: Other MPI error, error stack:
MPI_Type_contiguous(120): MPI_Type_contiguous(count=253,
MPI_DOUBLE_PRECISION, new_type_p=0xbfd42800) failed
MPID_Type_contiguous(44): Out of memory
[cli_6]: aborting job:
However, when I run the code on other cluster with mpich 1 as the
programming environment, the code runs smoothly.
Regards
Suman Vajjala
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090625/58f05dda/attachment.htm>
